Rep Power: 0 ![]() |
I have created a structured mesh using blocking for a 3d rectangular shape with variable area. After solving with cfx my results are not symmetric. When I checked the grid lines at the midplane it is different than the mesh i created using icem cfd. But other than the midplane(z=0), the grid is structured. May I know the reason or have i done any mistake in meshing.
Rep Power: 144 ![]() ![]() ![]() ![]() |
Is your question: what is that unexpected diagonal line on the mesh plot?
Answer: I suspect your plot is a cross section of the mesh, and you drew a cross section of the mesh at the midplane. Due to numerical approximations the mesh is not precisely aligned to the midplane, so this is where your mid plane section intersected the mesh midplane with its small numerical error. Is your question: I have a symmetrical mesh but my results are not symmetric? Answer: Yes, fluids do that. Have a look at flow around a cylinder: https://en.wikipedia.org/wiki/K%C3%A..._vortex_street
How to perform larger deformations while mantaining good mesh with adjoint solver | FormulaStudentFEB | STAR-CCM+ | 0 | October 13, 2023 11:27 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) | shubham jain | ANSYS Meshing & Geometry | 1 | April 10, 2017 05:03 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
