July 15, 2024, 01:22 |
CFX parallel cores of FSI
Evelyn
Rep Power: 5 |
Hello everyone, I am using the CFX module in the workbench and the transient analysis module to set up fluid-solid coupling. I set the number of parallel cores in the workbench tool and also set the number of parallel cores in the transient analysis.
For CFX, after I set the number of parallel calculation cores in the solution control of CFX-Pre, CFX prompted the following error: The Solver Input File value will be ignored when the solver is started as CFX-Pre is within ANSYS Workbench. However, when I tried to open the solution settings of the CFX module in the workbench main interface, I found that I could not open it directly. So how should I set up the parallel calculation of CFX? My software version is 2021R2, and the operating system is win11
biofluid mechanics;Hemodynamics Last edited by Yanlu; July 16, 2024 at 01:38. |
July 15, 2024, 05:19 |
Rep Power: 144 |
There are tutorial examples of how to set up fluid-solid coupling simulations in workbench. There are few steps to it so you should have a look at it before starting any of your own simulations.
July 15, 2024, 05:31 |
#3 | |
Evelyn
Rep Power: 5 |
https://www.youtube.com/watch?v=FN2MfWBv3Sk
biofluid mechanics;Hemodynamics |
July 15, 2024, 05:37 |
Rep Power: 144 |
Did you watch the video you posted? It says that was part 1, in part 2 or the video they set up the coupled analysis. So try part 2 of the video.
Or try the official tutorials which come with CFX. You will find the coupled solver tutorials under workbench (not CFX).
July 15, 2024, 05:44 |
#5 | |
Evelyn
Rep Power: 5 |
Thanks for your suggestions.
Call for help! Cfx error in Parallel run. | yq11ys | CFX | 5 | November 28, 2022 22:25 |
2-way FSI of a (composite) propeller using CFX | Leifheit | ANSYS | 0 | May 22, 2018 11:11 |
Parallel Computing for ANSYS CFX R17 | Noco | CFX | 7 | January 17, 2018 16:14 |
CFX for FSI | icemaniac178 | CFX | 3 | May 14, 2011 01:49 |
FSI : CFX or Fluent? | icemaniac178 | ANSYS | 1 | February 19, 2010 06:33 |
