CFX Pre: Transform mesh dialog does not appear |
Jiri
Rep Power: 13 ![]() |
Hi there,
in version 2023 R2, if I right click on a mesh in CFX Pre and select "transform mesh", the dialog window for transforming mesh does not appear. Do you have please any idea? I tried to change some properties in cfx5pre.exe but it did not help.. Thanks a lot! |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Has it appeared on another screen?
You can reset the display in CFX-Pre. Have a look at the top menu bar for this. If you want to reset the screen layout to default - you will obviously loose any customisation you have done - you can delete the temp directory in your home folder/directory. I think they are .ansys(VersionID) or something like that. When you restart CFX it will regenerate this using the defaults.
Jiri
Thanks for advice.
1) I cant see display reset in to menu bar in Pre.. ? 2) I deleted the file CFXPreferences.XML in folder c:\Program Files\ANSYS Inc\v232\commonfiles\registry\winx64\ but it does not work. In options, also tried CFX defaults and Workbench defaults... Another observation: the pop up window "Mesh Statistics" works. But the pop window "reload mesh files" does not emerge either... Any other ideas, please? |
Jiri
Heureka, I did it according to this:
https://innovationspace.ansys.com/kn...bar-i-can-see/ I deleted the .cfx folder in c:\Users\. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX | shiyun | ANSYS Meshing & Geometry | 4 | May 9, 2012 19:55 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
cfx mesh problem... | mactech001 | ANSYS Meshing & Geometry | 0 | November 5, 2009 02:19 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
