Boundary conditions at Fluid Solid interface (CHT)
Old   April 20, 2008, 09:49
Default Boundary conditions at Fluid Solid interface (CHT)
michelle
hi,
when i am trying to solve CHT problems,following the tutorial "CHT in a heating coil",the boundary conditions at the interface have been automatically taken as "conservative interface flux". this boundary condiition is one of continuity of heat flux.
Is there any reason why continiuty of heat flux is a better boundary condition than Continuity of temperature? And what shud we have to do if we want to impose continuity of temperature at the Fluid solid interface?
secondly, I also noticed that we do not specify any boundary condition for velocity at the fluid solid interface. Does CFX assume "No slip" for velcoity at the interface?
Thanks and regards, MIchelle
Old   April 21, 2008, 05:06
Default Re: Boundary conditions at Fluid Solid interface (
andy2O
Well, continuity of heat flux conserves energy, whereas continuity of temperature does not itself guarentee this! Most people (Newton, Bernoulli, etc...) are quite keen on conservation of energy
If there is no thermal resistance associated with the interface surface itself, then temperature will also be continuous across the surface. If you have a really good mesh, this should be reasonably obvious, but on a finite mesh there will always be some jump between (any) two cells if there's a heat flux.
"secondly, I also noticed that we do not specify any boundary condition for velocity at the fluid solid interface. Does CFX assume "No slip" for velcoity at the interface?"
Yes. I think you can see that by double clicking on the 'boundary condition' associated with the interface which CFX automatically places in the fluid domain once you have made the interface. However, I can't check that just now, so I can't be quite sure if it shows up clearly when you double click.
andy
Error message: Insufficient Catalogue Size Paresh Jain CFX 33 August 16, 2024 06:09
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
