Free Surface Flow with Sediment Transport
Old   April 17, 2008, 11:12
Default Free Surface Flow with Sediment Transport
M. Riffai
Hello CFX Folks,
I am trying to simulate flow over an embankment weir (small trapezoidal dam) where as the bed is mobile. I was successful in simulating the hydrodynamic part, but now I would like to include the effects of the mobile bed. So I believe it is possible to simulate the transport of sediment in three ways:
1- Eulerian-Eulerin Multiphase 2- Lagrangian Particle Transport (although CFX won't let me include two Eulerian-Eulerian models or two continuos phases like air and water with a dispersed phase like solid particles using the Lagrangian model) 3- Create a new material (water and sediment) and an additional variable such as concentration and solve a transport equation (e.g. Poisson or diffusive transport)
I would like some advice on how to define each phase in each of the cases above (if possible. I have a feeling the Lagrangian Particle Transport will not work because the air and water phase cannot both be continuous wtih a dispersed solid phase. I know this has been done before, and I'm sure there is a way around it).
Your help is very much appreciated. Thanks!
Regards, M. Riffai
Old   April 17, 2008, 20:51
Default Re: Free Surface Flow with Sediment Transport
This sounds like it would be best done as a discrete element model. These type of models can account for particle size and packing, settling and motion. At the moment you need to couple to a package like EDEM to do this, but I hear that CFX V12 has some capability in this area. Not sure if it will do what you are looking for.
Regards, Glenn
Old   December 1, 2011, 18:23
Javier Climent Agustina
CFD_UJI is on a distinguished road
Hello M. Riffa,
Finally, how did you define this model?
Option 1, 2 or 3? I'm really interested in this system.
I had several problems with option 2 as well, but I think it's the best approach. I wouldn't define solid particles as a "solid dispersed". On the other hand, air and water continuous phases are necesary.
Thanks a lot
CFD_UJI is offline   Reply With Quote
Old   September 5, 2013, 10:45
marjan
mdallali is on a distinguished road
HI
I wanna model the pickup rate as expression mentioned by van.Rijn as follow:
P=0.00033(tet-tet_cr/tet_cr)^1.5 * (s-1)^0.6 *g^0.6 *d^0.8/nu^0.2
which ni is diffusivity and s is ratio of densities and d is particle diameter.
How could I nondimensional this expression and relate it to froud-Numbewr and Reynold?
Thanks
mdallali is offline   Reply With Quote
Free surface flow over a bump qtian OpenFOAM Running, Solving & CFD 17 August 10, 2010 11:15
Problem with capturing water-spreading for free surface flow devesh.baghel OpenFOAM 2 December 10, 2009 02:21
free surface flow in non-inertial reference frame Tiedingg FLOW-3D 1 February 26, 2009 20:51
Free surface vortex flow Guillaume CFX 3 August 25, 2005 21:52
incompressible free surface flow past cylinder vineet FLUENT 2 April 1, 2002 06:56
