June 28, 2024, 09:39 |
how the velocity and pressure are coupled
Evelyn
Rep Power: 5 |
Hello everyone, I am curious about how the velocity and pressure are coupled in ANSYS CFX. Can I change to other solutions? When I verified the mesh independence, I found that after the number of my meshes increased, the pressure changed significantly, while the velocity and flow rate did not have a big effect. I want to know why this is the case.
biofluid mechanics;Hemodynamics |
June 28, 2024, 22:48 |
Rep Power: 144 |
In CFX the pressure-velocity coupling is inside the matrix, as it is a coupled solver. In other words, the velocity and pressure equations are all solved in the same matrix. This means no coupling step needs to be done, it is taken care of.
You cannot turn this off in CFX and use an uncoupled approach (eg SIMPLE). If you want to try an uncoupled approach you will need to use Fluent, StarCD or a different solver.
June 29, 2024, 00:00 |
#3 | |
Evelyn
Rep Power: 5 |
June 29, 2024, 00:16 |
Rep Power: 144 |
Then it sounds like your mesh is too coarse, you need to refine it further. For some general tips see FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
June 29, 2024, 00:22 |
#5 | |
Evelyn
Rep Power: 5 |
June 29, 2024, 00:31 |
Rep Power: 144 |
Pressure changes can be caused by very small changes in the velocity field in some cases.
Can you post images of what you are seeing, including something which shows the problem you are having, your geometry and attach your output file.
June 29, 2024, 06:45 |
#7 | |
Evelyn
Rep Power: 5 |
June 29, 2024, 06:52 |
Rep Power: 144 |
The website does support uploading, it just has a maximum file size. The CCL section at the top of the output file is the most important bit, cut that out and post that as an attachment please.
Thanks for the image of your geometry, but I have no idea what those graphs are showing. You will have to explain what we are looking at.
June 29, 2024, 07:34 |
#9 | |
Evelyn
Rep Power: 5 |
biofluid mechanics;Hemodynamics Last edited by Yanlu; June 29, 2024 at 23:38. |
June 29, 2024, 08:12 |
#10 |
Rep Power: 144 |
I see from your CCL that this is a transient model, you have complex functions controlling some boundary conditions and the fluid is blood, which you model as non-Newtonian. How are we expected to help you when you don't even tell us these critical and basic information?
Please explain what you are doing, what you are modelling, how you are modelling it and what the problem you are getting is. Your previous post shows many charts but I have no idea what any of them mean. I see your geometry and mesh, but what are the boundary conditions you are using on it?
June 29, 2024, 08:27 |
#11 | |
Evelyn
Rep Power: 5 |
The simulation in my paper and the new simulation I am having problems with now only modified the geometric model and the inlet flow, but now I have encountered such a problem. I am still looking for why the problem occurs.
June 29, 2024, 18:51 |
#12 |
Rep Power: 144 |
OK, so back to your original question - if the pressure distribution at the outlet is important to you and it is changing with mesh refinement, then you need to do a mesh refinement study to refine it further until you get a mesh independent solution. The fact that other parameters are stable is good, but until all parameters of interest are stable then you have not achieved mesh independence.
Note that as you refine the mesh you will need to change the time step as well. The easiest way to handle this is to use adaptive time stepping, homing in on 3-5 coeff loops per iteration. Then the solver will find its own time step size.
June 29, 2024, 23:34 |
#13 | |
Evelyn
Rep Power: 5 |
June 30, 2024, 04:31 |
#14 |
Rep Power: 144 |
It is in the time step settings, when you choose between a steady state and transient simulation. When you select a transient simulation it is one of the time step options.
June 30, 2024, 05:48 |
#15 |
Evelyn
Rep Power: 5 |
I found this setting and I will try to use it. Thank you!
obtain velocity from pressure profile | Deep111090 | OpenFOAM Running, Solving & CFD | 18 | July 15, 2023 07:41 |
divergence error in pressure termal couple | rezvani | Fluent UDF and Scheme Programming | 6 | January 27, 2021 23:54 |
Porous zone - setup of lab air tunnel - velocity v's pressure drop | RobertW | FLUENT | 1 | May 26, 2020 09:27 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
