Pls. help:how to include pressure at the interface
Old   April 17, 2008, 00:15
Default Pls. help:how to include pressure at the interface
AT
I am modeling the change of droplet's shape when it hit the wall. The spherical droplet is initially in liquid state and is at very high temperature. The wall is at room temperature. When the droplet hit the wall, the droplet will spread out, solidify and cool down to form a pancake-like shape. I currently set up multiphase setting and activate phase change for droplet (from liquid to solid).
The result so far is quite good. However, i would like to extent the model to include other factors. For eg., when the droplet hit the wall, the wall temperature increased. Then, some water on the wall surface will be vaporised . This vapor was at very high pressure which explode the droplet at the center where is the highest heat transfer coefficient. As a result, the pancake-like shape will look like a pancake with a bubble hole at the centre droplet(or a doughnut-like shape). Anybody know how to include this high pressure into the model, exp. at the interface of two domains (solid for wall and liquid domain for droplet)?. Or any way to account this effect.
I really appreciate your idea about this matter.
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
Is it important to include hydrostatic pressure? Nigelo Main CFD Forum 2 May 14, 2007 12:36
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
