Model validation stirred tank mixing time
Old   July 3, 2024, 16:34
Gert-Jan
Gert-Jan will become famous soon enough
Certainly there are more sophisticated methods to calculate the mixing time in Post. But if you can't measure this in practice, it has less value. Also, these all remain derived quantities. In principle they should all lead to more or less the same answer. Therefore I would remain comparing the mixing time from the monitoring point as monitored in the experiment. That is what you have in practice.
However, it is not said that this point is the most valuable, characteristic, or critical. Maybe you can find a location in your CFD that is more critical in your chemical/biological process? E.g. look for a region with still water conditions. Then I would advise to move the sensor to that location.
That is maximizing the power of CFD. You open the black box.
Gert-Jan is offline   Reply With Quote
bioreactor, cfx, mixing time, stirred tank, validation
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 09:27
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
