April 14, 2008, 07:07 |
Import geometry
I have got a geometry combustors realized in Sildworks. Is it importable in CFX without problem (about file extension)?
Thank you everyone |
April 14, 2008, 15:44 |
Re: Import geometry
Cristiano,
You can export it to Ansys Workbench and mesh it with CFX-Mesh. After that you just open the mesh on CFX-PRE. To export to Ansys WB, save it as IGES on Solidworks. You also com link it directly to SW model. You sould have an Ansys menu on Solidworks where you can do that. I hope it helps. Rodrigo Basniak |
April 14, 2008, 22:44 |
Re: Import geometry
yoU must use Part1.SLDPRT file to open on Design Modeler. Forget this kind of iges. file. I had problems with iges. files! If you wanna simulate different parts of you complete body (=assembly), you have not to choose the "merge" option on Solid Works, when you are creating (extruding) the second part of your assembly on SW.
Import geometry from CAD | Giuseppe (Giuseppe) | OpenFOAM Pre-Processing | 34 | December 14, 2017 17:24 |
[ICEM] Import geometry from solidworks | holyo | ANSYS Meshing & Geometry | 11 | April 16, 2014 12:47 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
[GAMBIT] import terrain geometry | cfdworker | ANSYS Meshing & Geometry | 2 | May 24, 2009 22:40 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
