help of the pressure in cfx-post
Old   April 13, 2008, 23:46
Default help of the pressure in cfx-post
nick
hi,guys I have two questions about pressure in cfx-post. 1.variable"pressure" or "total pressure"in cfxpost,which is equivalent to the value I measure with instrument(such as manometer). 2.if I want to know the value( as above "pressure")between to points,is there a direct way in cfxpost?(I know the probe tool can be used for one point.)
I'm a beginner,maybe these questions are simple for you , reply please!thanks a lot.
Old   April 15, 2008, 03:54
Default Re: help of the pressure in cfx-post
nick
maybe my questions are ridiculous,ok I have found the answer of the first question.Both can be measured by their respective instrument which I didn't know before. next,about the second question,is there a direct way in cfx post to acquire the value between two points? please give some hint.thanks all
Old   April 15, 2008, 13:41
frank
yes,there is a simple way to get the value.just write a perl command file to deal with it.you can check the helf file about this.
Old   April 16, 2008, 03:35
nick
yes,I find some explaination about this.I feel so much for me to study. thanks for your clue,frank.
Reference Pressure CFX solomedic CFX 12 August 3, 2014 06:22
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 14:22
negative pressure in cfx flar.t CFX 1 December 19, 2006 00:20
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
