Supersonic Turbine massflow change in choking area |
Rep Power: 5 ![]() |
Hi everyone!
I am analizing a supersonic turbine vane (NGV subsonic and rotor supersonic) with ansys CFX. The domain has a subsonic part which is the same in 3 different simulation (so all of them have the same chocking area) and i had some changes far from the choking area. Since i have in all the simulation the same inlet and outlet conditions and the same choking area (I checked I have M=1 always in the same spot), shouldn't i have to find the same massflow in all three of them, no matter what geometric changes i do in the supersonic part? Cause I find 3 different values of massflow (massflow change even about 30%!!!) I am imposing total pressure and static temperature at inlet and pressure at outlet. What am I missing? Thank you! |
#2 | |
Rep Power: 33 ![]() |
Thanks for your answer Opaque.
Sincerely I didn't get your answer. I am specifying at inlet the same value of total pressure and static temperature in all 3 cases. So since I have the same boundary conditions (both at inlet and outlet) and the same geometry in the subsonic domain and in choking area, I am expecting to have the same mass flow |
#4 | |
I was surprised you did not use "Total Temperature" boundary condition for a highly compressible flow model.
Thanks for the answer! Ok I am new in this, so I'll try to use total temperature and see what is going on
cfx, chockingarea, massflow, supersonic/subsonic flow, turbine |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 05:27 |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 14:07 |
CFX overpredicting turbine massflow | sherifkadry | CFX | 3 | February 1, 2010 03:15 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
how to change blade leading angle of axial turbine | dia aisa | CFX | 0 | June 2, 2008 02:45 |
