What is Periodic condition??
Old   April 9, 2008, 06:10
Default What is Periodic condition??
vijay
Dear friends,
I am trying to simulate "flow over an infinite flat plate". I am taking a plate of unit width. I think I have to use "interface domain" BC to solve this. It asks to specify 2 regions in that. I have (a)inlet (b)outlet (c)symmetry & (d)wall-no slip boundary conditions. (c) & (d) are in between (a) & (b).
Questions: Which boundary is periodic?? Which regions I have to specify for "interface domain" as region-1 & region-2 ? At the same time, I have some known velocity at the inlet.
Plz reply.
Old   April 9, 2008, 07:12
Default Re: What is Periodic condition??
Usman
(a) and (b) should be specified as periodic. You can decompose the symmtery into two symmteries and specify that as periodics as well.
You will have to specify a mass flow rate or pressure gradient to sustian the flow in domain.
- Usman
Old   April 10, 2008, 09:40
Vijay
Thanks Osman. But, once if I specify "inlet" & "outlet" as "region 1" & "region 2" periodic interfaces, I will not be able to apply any mass flow rate, pre grad or velocity etc. How can I apply these at inlet/outlet??
Old   April 10, 2008, 10:44
Usman
You will have to activate mass and momentum box on domain interface form and then specify pressure gradient or mass flow rate.
Usman
Periodic boundary condition in 2 directions arash FLUENT 21 July 25, 2018 13:44
Periodic boundary condition Arif FLUENT 3 March 9, 2017 02:18
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 29, 2010 00:32
Periodic Boundary Condition for upwind difference yohey44 Main CFD Forum 0 October 27, 2010 14:10
construct a periodic boundary condition in Gambi? Daniel FLUENT 0 October 17, 2006 11:28
