multiphase... solid volume fraction anomaly
Old   April 9, 2008, 00:09
Default multiphase... solid volume fraction anomaly
Tim
When I run a multiphase simulation and proces the results, a contour of the volume fraction of the solid particles results in areas where the volume solid fraction is 1, even though I have put in a maximum volume fraction of 0.62. I have designated seperate velocity fields for the solid particles and the continuous fluid, could this be why? Here are some of the details.
air continuous fluid solid particles 1 mm diameter dispersed, 50% volume fraction k-epsilon turbulence model sato enhanced eddy viscosity restitution coefficient 0.5 gidaspow solid pressure model
Thanks, Tim.
Old   February 13, 2012, 06:47
mugenzj is on a distinguished road
Hi I am having the same problem too! The initial static solid volume fraction of the bed is equals to 1 despite setting my solid as a dispersed solid. Can some1 please help me out with this issue? Many thanks.
mugenzj is offline   Reply With Quote
Old   February 13, 2012, 11:45
Cluain is on a distinguished road
I'm no expert, I’ve only dealt with fluids, but I'd say the simulation did not accept your input and hence you got 1 for one medium and 0 for the other.
The joys of learning CFX
Cluain is offline   Reply With Quote
Old   February 13, 2012, 14:57
Max
max3.2 is on a distinguished road
solver cant guarantee to keep below packing limit. period.
(thats what i got out of thr doc, but it was some time ago...)
max3.2 is offline   Reply With Quote
Old   February 14, 2012, 05:01
Hmm actually I was thinking whether it has got anything to do with the definition of the "solid volume fraction". Is it the absolute value or is it the value relative to the maximum packing? hmmm.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
volume fraction = nan Virtual-iCFD OpenFOAM Running, Solving & CFD 8 June 12, 2015 19:15
multiphase volume fraction defintion daniebae CFX 3 September 2, 2011 06:01
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Scaling volume fraction in Multiphase flows CFDtoy Main CFD Forum 1 November 5, 2008 08:26
