heat transfer in two-phase flow
Old   April 8, 2008, 06:57
Default heat transfer in two-phase flow
Leonid Fromzel
I tried to model two-phase air/oil flow inside the cavity. Oil is delivered from one inlet hole, whereas air is delivered from another inlet hole. Air-oil mixture is evacuated from outlet hole. Mixture model was applied with air and oil both treated as continuous phases.
I did this analysis in the following subsequent steps: - first stage - I modeled isothermal flow - oil and air temperatures are the same, cavity walls are adiabatic. Results were obtained with sufficient accuracy. OK.
- second stage - different temperatures of the air and oil at the respective inlets, homogeneous heat transfer model, results from the first stage were used as initial conditions. Results were obtained with sufficient accuracy. OK.
- third stage - different temperatures of the air and oil at the respective inlets, inhomogeneous heat transfer model with user supplied correlation for heat transfer coefficient (HTC) between the phases, results from the second stage were used as initial conditions. Solution failed because oil maximum temperature exceeds reasonable limits in one small local area near air inlet. To fix this problem I tried to implement or change the following -correlation for Nu number instead correlation for HTC -very big constant HTC (10^6) -very small constant HTC (actually zero) -constant oil properties instead of user supplied temperature dependent properties -different time steps -different advection schemes for energy equations -etc
No one of these approaches led to sucsess.
I am totally confused because from my point of view homogeneous heat transfer model and inhomogeneous heat transfer model with very big HTC should give just the same results.
What do you think about this problem? Thanks
Phase change heat transfer Lexa FLUENT 0 October 10, 2011 03:53
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 09:48
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Flow and Heat transfer in a Thawing chamber B.Prabhu FLUENT 0 May 12, 2002 16:13
