Dimension issues using CEL
Old   April 7, 2008, 13:51
Default Dimension issues using CEL
Andy
hi,
I'm trying to write an expression for the input flow where the velocity varies with height as u=0.49ln(3631.82h) when I try this in ANSYS CFX I get an error saying that it expects the argument of the ln function to be dimensionless but obviuosly it's in m.
any help would be appreciated
Andy
Old   April 7, 2008, 21:51
Default Re: Dimension issues using CEL
Rogerio Fernandes Brito
make like this (where "Fluxrogerio" is the name of my variable in [W m^-2] and t is the time in [s] and more, A and B were created by myself just to become a dimensionless variable) :
Fluxrogerio (B*(19453.29701*(t/A)^3.07678)/(4.73947^3.07678+(t/A)^3.07678))
A 1.0 [s] B 1.0 [W m^-2]
Old   April 8, 2008, 04:50
andy2O
Note that h / ( 1 [m] ) is dimensionless. Note that because the output of 0.49*ln(....) will be a dimensionless number, you will have to assign the correct units to the expression yourself to use it as a velocity in CFX. So... If h is measured in metres, and u in metres per second, then you should replace:
u=0.49ln(3631.82h)
with
0.49 * ln(3631.82 * h / (1 [m]) ) * 1 [m s^-1]
or, equivalently:
0.49 * ln(3631.82 [m^-1] * h) [m s^-1]
There are several ways of typing it - I think it's up to you to choose the one that makes sense to you.
( NB: If you use other units of distance or speed you must alter the choice of units or add in conversion factors otherwise the answer will be wrong! )
HTH
Andy2o
Old   April 8, 2008, 07:45
Andy
great, thanks for your help
Old   April 8, 2008, 07:49
You´re welcome!
Angle variable under CEL. Gloria Gaynor CFX 11 November 26, 2012 07:29
the problem about dimension bojiezhang OpenFOAM 2 October 16, 2011 01:22
junction box routine and CEL function bornspur CFX 2 February 3, 2009 03:24
Rotate node via cel Elian81 CFX 2 September 25, 2007 06:31
dimension lucy FLUENT 1 July 13, 2001 13:42
