Default particle wall interaction competing with user wall interaction |
May 13, 2024, 16:19 |
Hi everyone,
I have a case of quartz particles being transported with air in a domain. I am trying to implement a user defined particle-wall interaction through a Particle User Routine. This routine takes in two arguments - Quartz.Particle Impact Angle and Quartz.Velocity on a wall. It returns two things - the perpendicular and parallel coefficient of restitution. The reason I am using a Particle User Routine is because neither a CEL expression nor a general User Fortran can access the particle impact angle, a track variable. I've attached an image of the settings. To use this routine, I turned on User Wall Interaction (inside the blue oval) and used the Particle User Routine I defined. The problem, however is that I am unable to turn off the default wall interaction (inside the red oval), which is making cfx throw an error in Solution Manager, at the end of the simulation. Do you have a solution to this? |
cfx + fortran, particle tracking, user defined |
Illegal cell label -1, fluent3DMeshToFoam | BenGher | OpenFOAM | 7 | October 10, 2023 01:02 |
[snappyHexMesh] How to draw a 3D-Drawing for Meshing | Kahnbein.Kai | OpenFOAM Meshing & Mesh Conversion | 4 | June 15, 2021 13:16 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 01:52 |
particle user routines | Felix | CFX | 1 | July 24, 2006 13:32 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
