Jet flow problem.. PLZ help URGENT!!
Old   April 3, 2008, 13:26
Default Jet flow problem.. PLZ help URGENT!!
Vinayak
Dear friends, I want to simulate a jet flow. Air comes out from a jet of 5 X 80 mm slit. I have to use a turbulence model. Which turbulence model will be suitable for this problem??
I am also solving an external flow problem where Mach number is 10. Which turbulence model will be suitable for this problem. I am interested in determining drag and temperature distribution over the surface of the body.
PLZ REPLY.. ITS URGENT..
Old   April 3, 2008, 19:02
Default Re: Jet flow problem.. PLZ help URGENT!!
Jet - depends on the Reynolds number and also what type of results you are looking for. SST is a good starting point but some circumstances might need an LES approach.
Mach 10 - Generally very simple zero and one equation turbulence models are used for hypersonics but again that depends on what you are trying to model. You might need a two equation model. I would probably start with SST again.
Glenn
flow past abdominal aorta. Complex BC problem. ziemowitzima OpenFOAM Running, Solving & CFD 1 July 26, 2022 06:12
Urgent Help !!!Strange reverse flow in naca0012 problem parvez2683 FLUENT 5 May 20, 2013 10:25
Flow not moving - Supersonic/Initial Pressure problem? shankara.2 FLUENT 0 June 9, 2009 21:49
Plz help. Urgent! MHD problem Rucy FLUENT 0 May 25, 2007 07:35
IMPINGING JET PROBLEM Chuck Leakeas Main CFD Forum 4 January 29, 1999 18:43
