April 3, 2008, 12:14 |
Free slip in CFX??
Dear friends,
What is meant by "Free slip" in cfx?? how it differs from "no slip" condition?? PLZ reply.. Thanks in advance.. |
April 3, 2008, 12:35 |
Re: Free slip in CFX??
This is fundamental to fluid dynamics.... If this is not familiar to you I suggest you stop doing CFD work for a while and read a good book about viscous flow!
No slip -> Fluid velocity = 0 at stationary boundary. This is the usual condition for viscous flow at a wall. Free slip -> Normal component of fluid velocity = 0 at stationary boundary. Tangential component of velocity can have any value. The extension to moving boundaries is obvious: you consider velocity relative to the boundary and apply the rules above. HTH, Andy. |
April 3, 2008, 14:12 |
normally a no-slip condition is used in viscous flow calculation. If u are simulating a non-viscous fluid (for example an Euler flow) at the boundary u have that the fluid velocity is not zero. Anyway also in case of viscous flow u can have a slip boundary condition, for example in rarefied flow (e.g. high altitudes...)... ok? cheers J |
April 7, 2008, 04:53 |
Thanks friends...
August 20, 2013, 23:34 |
free slip boundary condition for gas
mohamad
Rep Power: 14 |
Hello
I study gas- liquid bubble column. and I use free slip boundary condition for gas base on previous study. I want to understand why I have to use this boundary condition for gas. Thank you. |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
free slip boundary conditions | Yang | Main CFD Forum | 8 | May 22, 2011 22:14 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
Free rotating machinery CFX seminar | ANSYS CFX Marketing | CFX | 0 | October 6, 2003 11:14 |
