ICEM for CFX
Old   April 2, 2008, 16:15
Default ICEM for CFX
Al Mazdeh
i JUST RECENTLy recived a license for ICEm
i LIKE TO MESH with icem AND then BRING IT IN TO cfx pre
WHEN i CREATED MY MESH IN icem after saving it, I didn't get the readble mesh file by cfx pre
as u know the format acceptable by cfx pre for ICEM is *.mesh
but when I SAVED IT in icem, it only created *tin, uns and prj file what is wrong?
Old   April 2, 2008, 16:30
Default Re: ICEM for CFX
hp_c360
Maybe you should try to select CFX as your solver in the "output to solver" menu. You could set up your bc there, too. Then: Write your output! hth...
Old   April 3, 2008, 08:23
Marek
You have to select solver (ANSYS CFX in your case) and write output from ICEM CFD not just save ICEM CFD format (*.uns).
Old   April 3, 2008, 15:51
Al Mazdeh
I did exactly what u said but I do not see any file being written. So what is the problem?
It is writing this massge in that small box window
oading C:/Program Files/Ansys Inc/v110/icemcfd/win/icemcfd/output-interfaces/cfx5.bcinfo Solver ANSYS CFX supports unstructured mesh.
Old   April 3, 2008, 17:44
Marek
Be sure that in the window is written: "Done with translation". If not, something is wrong with your mesh and first you have to fix or repair it. No input was made. If everything is OK and translation was done, *.gtm or *.cfx5 input was written.
Old   April 4, 2008, 14:23
Al Mazdeh
thanks a lot I have got it in CFX-
now there is another problem - the mesh created in ICEM doesn't have any regions It came in as a single unit so I DO NOT KNOW HOW i CAN DEFINE MY b.c.S
THANKS FOR replying my emails
Old   April 4, 2008, 18:51
Usman
Hi Al Mazdeh
You will have to create parts in ICEM to define BCs in CFX-Pre. Easiest way to learn it would be to go through a tutorial.
Usman
Old   April 5, 2008, 07:32
sivaramakrishnaiah
ok your using cfx-11,or cfx-10 in cfx-11---press it outpt mesh enter in that one window willcome in that two options will put 1st options put ansys,2nd that one put ansys cfx. after that save mesh . ok
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 07:50
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 03:33
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 04:39
ICEM 10 mesh scale foe CFX Korsh Mik CFX 2 October 7, 2005 10:07
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 07:46
