Boundary Conditions for Rudder in Hemisphere
Old   March 31, 2008, 21:26
Default Boundary Conditions for Rudder in Hemisphere
Ronan
Im trying to model a rudder that is fitted to a symmetry wall at the roof of a hemishperical region. There are inlet and outlet conditions that are fine on the front and rear sides of the hemisphere but I cant figure out what conditions are required at the sidewalls of the region? Supposedly the are not walls though, openings maybe? Heres a link to a picture, the highlighted areas are the ones Im talking about: http://img.villagephotos.com/p/2006-...9/untitled.JPG
Thanks Ro
Old   April 1, 2008, 16:42
Default Re: Boundary Conditions for Rudder in Hemisphere
Steven
Hi
Can you not just get rid of them completely and just extend you inlet and outlet to make a two half spheres? What is the situation you are modelling?
Steven
Old   April 1, 2008, 18:34
Ronan
Just modeling a rudder at 0 and 15 degrees angle of attack, its a project for University and we've been supplied this mesh...
Old   April 3, 2008, 17:07
Jonathan
A Free Slip Wall will have the minimum impact on the solution.
Mind you if the wall is hemispeherical maybe the normal velocity=0 condition might actually be false.
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
Boundary conditions for 2D Navie-Stockes simulation L1011 OpenFOAM 5 December 13, 2012 09:17
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
