Propeller simulation not matching experimental data
Like Tree12Likes
Old   April 12, 2024, 15:25
Default Propeller simulation not matching experimental data
Kevin Gnanaraj
keg504 is on a distinguished road
I'm trying to do a simple propeller simulation based on this paper: 3D CFD Simulation and Experimental Validation of Small APC Slow Flyer Propeller Blade (Kutty and Rajendran, 2017), using a different 22 in propeller from T-motor. I've set up a simulation using both Frozen Rotor and Mixing Planes in CFX, and tried a few different Boundary Conditions: inlet: velocity, mass flow and total pressure, outlet: avg. static pressure, static pressure, opening), conducted a mesh independence study, and none of these seem to match the experimental thrust. (Mixing planes always ends up with floating point overflow, even with double precision). Right now, I'm trying a physical timescale of 1/propeller rotational velocity (rad s-1). I have been using the k-omega SST model.
What I am trying to do is a static thrust study of the propeller. Can someone point me to to a paper or resources on how to set this up correctly, or explain the appropriate boundary conditions? I've been stuck on this issue for a month, and I'll need to move to a co-axial co-rotating study once this is done, so I want to get this right and understand why before moving on. An issue I'm seeing is that the velocity leaks radially instead of through the propeller. Hopefully I've attached the images correctly.
keg504 is offline   Reply With Quote
Old   April 12, 2024, 18:46
What are you trying to model? What results do you want to see (I think you said you want static thrust)? What conditions is this running at (ambient velocity, atmospheric conditions, surrounding fluid, rotor speed etc)?
What conditions is this fan designed to run at?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   April 12, 2024, 18:55
Default Clarification
Kevin Gnanaraj
Apologies, I overlooked adding those details. This is the experimental data I am trying to model: https://database.tytorobotics.com/te...-motor-ns22x66
Essentially, this is for a drone propeller at hover conditions at sea level at ambient velocity (assuming still air for now). I was trying to run it at the highest thrust (4471 RPM). This is supposed to be in open air. I'm not sure what other details you need, but I'll try to tell you if I know them.
I also got a floating point error just now for mixing planes for the physical timescale I mentioned of 1/propeller rotational velocity (rad s-1).
Last edited by keg504; April 12, 2024 at 18:58. Reason: Added more information from recent simulation
Old   April 12, 2024, 19:19
How many blades does the propeller have?
Old   April 12, 2024, 19:47
Kevin Gnanaraj
Two blades, I am using half domain symmetry on the domains though.
Old   April 12, 2024, 22:04
Opaque will become famous soon enough
Be careful with the vocabulary here. Are you using Symmetry or a Domain Interface with Option = Rotational Periodicity?
In Ansys CFX, Symmetry is planar and represents a mirror condition.
Opaque is offline   Reply With Quote
Old   April 13, 2024, 07:34
Kevin Gnanaraj
It is a symmetry boundary condition, I am only simulating one blade to reduce computational time.
Old   April 13, 2024, 08:04
You are using the wrong boundary condition. You should be using rotational periodicity on both the rotor domain and the ambient domain. Your incorrect use of a symmetry boundary condition is one of the reasons why the results are weird.
Have a look at the rotating machinery tutorial examples for CFX to see how rotating machinery simulations should be set up.
Opaque likes this.
Old   April 13, 2024, 08:24
Kevin Gnanaraj
Ok, I didn't realise, I will take a look at it and report back once I've run a simulation. I presume this tutorial is within ANSYS CFX's help?
Thank you!
Old   April 13, 2024, 18:59
Thank you!
In CFD modeling, in particular turbomachinery, the word Symmetry is used for Cartesian symmetry/mirror symmetry, and Periodicity is used for repetitive symmetry be it translational or rotational.
In Ansys CFX, symmetry enforces no flow crossing, i.e. V dot N == 0. That is not a valid BC for modeling a reduced "repetitive model"
In structural modeling, the wording is a bit different: rotational symmetry, or cyclic symmetry (time and space).
I would not be surprised, other vocabulary is used in other fields as well.
Summary: vocabulary is EXTREMELY important.
Old   April 13, 2024, 22:39
You can access the tutorials on the ANSYS Customer page. For academic customers I think it is on the ANSYS academic site as well, but I have not checked.
You can also do a google search for "CFX turbomachinery tutorial" and you will find lots of them.
Old   April 15, 2024, 06:40
Default Results based on new information
  #12
Kevin Gnanaraj
So I ran a simulation based on the periodic boundary, and I'm pretty sure that the inlet boundary condition is wrong (I used an absolute pressure of 1 atm), and you can see the results below. This is still with FR.
Is it that the velocity inlet is correct for static thrust? I did ask a professor at my university, and he told me that wind tunnel conditions should be used, which has a stagnation inlet. In that case, does it mean that the dynamic pressure for the stagnation pressure is calculated using the expected exit velocity for the thrust based on momentum theory? (I used this reference: https://www.grc.nasa.gov/WWW/k-12/airplane/propth.html)
Old   April 15, 2024, 07:12
I would set a reference pressure of 1 atm, and make all outer boundaries an opening at 0 Pa. The rotor and ambient domains have the rotational periodicity interfaces, of course.
Old   April 16, 2024, 05:27
Default Simulation running
  #14
Kevin Gnanaraj
Currently running a simulation, will take a day more to get results, here are the residuals so far.
First for frozen rotor:
Next for mixing planes:
Old   April 16, 2024, 05:38
Why keep running it? It converged as tight as it is able at about iteration 50 and everything beyond that is a waste of time. See this FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
Old   April 16, 2024, 06:04
Default Results
  #16
Kevin Gnanaraj
I was waiting for the turbulence residuals, since those seemed to be on a downward trend when I checked yesterday, but they were also oscillating now. Here are the pressure distribution results, and as you can see, there is little improvement. I will try running it without the periodic boundary, instead with the whole rotor to simplify it a bit, since it's converging quickly anyway.
Here are the mixing planes results, which got a thrust of 1469.27 N (it's supposed to be around 45 N)
And here it is for the frozen rotor (thrust of 1205.39 N, for same conditions)
Old   April 16, 2024, 06:26
Your thrust is a long way off what it is meant to be, so something is seriously wrong with your simulation.
Please read the documentation about the GGI interface models - frozen rotor, mixing plane and the others. I think you will find the mixing plane model is not appropriate for what you are trying to do.
Please post an image of the mesh near your blades, the flow near your blades and your output file. You can trim the output file down to the first 50 iterations if you like. Please post it directly on the forum, do not use third party sites.
Old   April 16, 2024, 09:49
Default Images and output
  #18
Kevin Gnanaraj
Thanks for the help so far. Please see the mesh, flow and outfile attached. I'm not sure if this is what you were asking for in terms of the flow near the blade, it is taken from the centre point of the blade. If you need better images, let me know what kind. The forum seems to have blocked me from connecting because I messed up with the attachements earlier
Mesh
Pressure around blade
Velocity around blade
Outfile
FR_100.txt
I have noticed that double precision is off even though I have set it to on in the bash script as follows:
#!/usr/bin/env bash
#SBATCH -A C3SE2024-1-15 -p vera
#SBATCH -J UAV_thesis
#SBATCH -n 32
#SBATCH -t 2-12:00:00
#SBATCH --mail-user=gnanaraj[at]chalmers
#SBATCH --mail-type=BEGIN,END,FAIL
#SBATCH -o out.stdout
#SBATCH -e err.stderr
module load ANSYS/2021R1
nodes="sed -e :a -e N -e 's/\n/,/' -e ta $TMPDIR/mpichnodes"
/apps/Common/software/ANSYS/2021R1/v211/CFX/bin/cfx5solve -def CFX.def
-par -par-dist $nodes -start-method "HP MPI Distributed Parallel" -double
#end of script (make sure line before this gets run)
The reason I am using mixing planes as well is because I want to run the propellers in a co-axial contra-rotating configuration after I have validated this. The CFD Online wiki suggests that mixing planes would be better because in frozen rotor, the blades are fixed in place, and flow is dependent on the relative positions, so I thought that it would be a more valid comparison for my report if the same interface was used for both simulation types.
Last edited by keg504; April 16, 2024 at 09:56. Reason: added little more information, grammar correction, removed email
Old   April 16, 2024, 19:33
I see lots of problems in your output file:
1) Your inlet is 1atm and your outlets are 0atm! This is going to create a cyclone from the inlet to the outlet. Is this what you intended? I would expect that all external boundaries should be set to 0atm pressure.
2) Your reference pressure is 0 atm. If this device operates at normal atmospheric conditions then use a reference pressure of 1 atm. This reduces round off errors.
3) You probably want to use double precision numerics. It is easy to implement and can help so you might as well.
4) There are warnings saying you cannot use pitch change specified by angles and you should use option = None. I would implement this advice.
5) You have 4 interfaces. Why so many? Also, some of them are showing high non-overlap areas fractions. This suggests some of your interfaces are not connecting properly.
6) Your convergence is poor. Read the FAQ I linked to in my previous post. Also the things I have mentioned here will also help convergence.
Opaque and keg504 like this.
Old   April 17, 2024, 05:58
Kevin Gnanaraj
1&2 - Ok, points 1 and 2 were completely my bad, I misunderstood the boundaries and pressures you mentioned.
3 - I have turned it on now, since I put the flag in the wrong location
4 - I used the suggested pitch change of None
5 - I combined the FR interfaces to 1 (I didn't realise you could select multiple locations)
I am running a simulation with these changes, and adjustments to improve convergence. Fingers crossed that this works!
Last edited by keg504; April 17, 2024 at 05:58. Reason: Removed character that wasn't displaying
floating point exception, mixing planes, propeller flow error
[OpenFOAM] Paraview python script, creating data using only CLI, saving in csv/excel file Ash Kot ParaView 1 September 24, 2021 13:23
Error running AMI propeller simulation luitzor OpenFOAM Running, Solving & CFD 0 April 19, 2021 14:48
Pump CAD + experimental data for CFD verification study bemism Main CFD Forum 0 July 20, 2017 16:30
Data Produced From Fine Marine Cant Match with The Experimental Data PeiSan Fidelity CFD 4 August 23, 2014 06:33
How to compare the average velocity of the simulation with the Experimental data ? nanavati OpenFOAM Post-Processing 2 August 22, 2014 05:48
