March 26, 2008, 16:29 |
Iteration number for junction box routine
I am using a junction box routine called after every time step in a transient run. I would like to make statements which determines wether to read information from a file after the first time step and save these in the memory in fortran or to read the information from the memory after the preceding time steps.
Basically i need to call the iteration number which attain the values 1,2,...,n for the i´th iteration. I have tried to call atstep, ctstep, Accumulated Time Step, Current Time Step, but I get the same value after each time step. I have found something about CALL_TRANS_INFO but nothing which explains how this works. Can anybody help me? |
March 27, 2008, 08:50 |
Re: Iteration number for junction box routine
I might now rephrase my question. I have found out that I might be able to get the information needed by specifying an expression as:
timevariable = aitern Then I define an additional variable which I assign the value of "timevariable". But now my problem is how to call an additional variable in Fortran? I have read in the manual that "USER_GETVAR" does not work in a junction box routine and I am therefore lost as to what I can Call to get the variable into my fortran routine at each time step. |
April 13, 2009, 16:16 |
Ahmad
Rep Power: 17 |
Try the subroutine below. You can find an extended version in CFX-PRE documentation.
#include "cfx5ext.h" dll export(get_tstep_info) SUBROUTINE GET_TSTEP_INFO (CZ, DZ, IZ, LZ, RZ) C C Example of obtaining transient info for all domains C C Include directives #include "MMS.h" #include "cfd_constants.h" C C Arguments CHARACTER*(1) CZ(*) DOUBLE PRECISION DZ(*) INTEGER IZ(*) LOGICAL LZ(*) REAL RZ(*) C C External functions C Functions to convert integers/reals to character strings CHARACTER*4 CFROMI, CFROMR C Function to concatenate an integer on to the end of a string CHARACTER*(MXDNAM) CCATI EXTERNAL CCATI, CFROMI, CFROMR CHARACTER FILENAME*8 CHARACTER ATSTEPCHAR*4 INTEGER I,N C C Local parameters CHARACTER*(*) ROUTIN PARAMETER (ROUTIN = 'GET_TSTEP_INFO') C C Local variables CHARACTER*4 CRESLT CHARACTER*120 User_Domain_Name CHARACTER*(MXDNAM) CDIR_GLOB, CZONE CHARACTER*(MXPNAM) CDRNAM C C Number of zones & iterator INTEGER NZN, IZN C Number of timesteps, accumulated timesteps, coefficient loops INTEGER NTSTEP, ATSTEP, NCLOOP C Time, accumulated time, timestep value REAL RTIME, GTIME, DT C C ================================================== ==================== C Executable statements C ================================================== ==================== C C ---------------------------------------------------------------------- C Obtain and write non zone specific data C ---------------------------------------------------------------------- C C Obtain number of timesteps and accumulated timesteps CALL PSHDIR ('/FLOW/SOLUTION', 'STOP', CRESLT) CALL PEEKI ('NTSTEP', IONE, NTSTEP, 'STOP', CRESLT, IZ) CALL PEEKI ('ATSTEP', IONE, ATSTEP, 'STOP', CRESLT, IZ) CALL POPDIR ('STOP', CRESLT) C Write to standard output CALL MESAGE( 'WRITE-ASIS', ' ') CALL MESAGE( 'WRITE', ' Time Step = '//CFROMI(NTSTEP)) CALL MESAGE( 'WRITE', ' Accumulated Time Step = '//CFROMI(ATSTEP)) END |
April 14, 2009, 06:03 |
Martijn
Rep Power: 17 |
I had some time ago the same problem, and solved it by writing a text file with the value of atstep with a User Cel function which is later on read by the junction box routine. It is easy and works always .
March 7, 2018, 09:45 |
Junction box routine
Laghouat
Rep Power: 8 |
Hi all
me also, I want to set up a simulation in Ansys-cfx with user Junction Box Routine(in Fortran). This JBR is called at the end of each timestep in order to get the the velocity field components (for special area), treat them and inject them again into the solver for the next time step.So, my question is exactely how can a user fortran routine deal (get ,inject...) with the velocity field components every timestep. Please I need your help or a tutorial for this special purpose Thanks for all |
March 7, 2018, 11:51 |
#6 | |
Rep Power: 18 |
March 7, 2018, 17:42 |
Rep Power: 144 |
Laghouat: You posted the same post on 3 threads. Please do not do this again. Ask a question once and once only.
March 8, 2018, 07:35 |
Laghouat
Rep Power: 8 |
March 8, 2018, 07:55 |
#9 |
Laghouat
Rep Power: 8 |
Hi Antanas
I don't understand your reply "RTFM ". Breafly my question is, how can we get velocity fiel solution after each timestep, treat it and reinject it again as initialisation for the next timestep.All this with a JBR defined in ANSYS-CFX pre.If I understood correctly USER_GETVAR do not work with JBR. please I need your help . |
junction box routine and CEL function | bornspur | CFX | 2 | February 3, 2009 03:24 |
junction box routine - more than one? | Ollimarc | CFX | 1 | March 18, 2008 03:32 |
Junction Box Routine Shared Object Library | sam | CFX | 0 | March 3, 2008 13:52 |
User CEL or Junction Box routine? | Lexi | CFX | 6 | January 22, 2004 09:52 |
junction box routine | Lexi | CFX | 2 | January 21, 2004 05:55 |
