Wall Shear in User Fortran
Old   March 26, 2008, 06:29
Default Wall Shear in User Fortran
Allan
I am trying to determine the wall shear from a junction box routine. I have a square building which I have divided into sections and used a step function to sort out the respective pressure and wall shear on the respective section. See examples below.
p2 = p * step(((2*dz)-z)/1[m])*step((z-((1)*dz))/1[m])
sx2 = wall shear x * step(((2*dz)-z)/1[m])*step((z-((1)*dz))/1[m])
I then define the same number of additional variables and assign the corresponding variable the value of the expression.
In Fortran I call the variables at each timestep in a transient run by USER_GET_GVAR. In the examples below, VARNAME_F is the respective pressure for the section in question and VARNAME_SX corresponds to a wall shear x variable as defined above.
CALL USER_GET_GVAR(VARNAME_F,DOM,'areaInt_x',CRESLT,PX( i,1),CZ,DZ,IZ,LZ,RZ)
CALL USER_GET_GVAR(VARNAME_SX,DOM,'areaInt_x',CRESLT,SX (i,1),CZ,DZ,IZ,LZ,RZ)
I use the same procedure for the y and z directions. But when I try to run the simulation the solver stops after the first timestep when runnning the junction box routine and express the following error message:
Error in subroutine cal_TAUWALL_TURB :
Called for invalid locale: VERTICES
GETVAR originally called by subroutine CAL_BCP_Aver_IP
+--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction.
| | Message:
| | Stopped in routine GV_ERROR
If I exclude the wall shear terms in my fortran routine there is no problem and the simulation keeps on running.
Does anyone have any idea as to where I could have made some mistakes or what needs to be set in CFX-Pre to make the USER_GET_GVAR functions for the wall shear work?
Thanks
Allan
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 01:52
Wall shear stress distributions en51nm STAR-CD 2 January 28, 2010 05:42
Post processing - Wall shear stress Carlo Siemens 1 March 4, 2009 08:35
User fortran routines, DEBUG AND OUTPUT Bloshchitsyn Vladimir CFX 5 October 29, 2007 02:31
