ERROR #001100279 has occurred in subroutine ErrAction.
Old   April 1, 2024, 11:57
Unhappy ERROR #001100279 has occurred in subroutine ErrAction.
Zoran Grete
zorgre is on a distinguished road
Hello everyone, I'm trying to run a Transient Blade Row of a centrifugal pump and everytime I try starting the sim, I get this error:
| Host Memory Information (Mbytes): Solver |
| Host | Npart | System | Allocated | % |
| ZORANS_LAPTOP | 4 | 65244.87 | 47591.21 | 72.94 |
| ****** WARNING ****** |
| This Transient Blade Row run may experience robustness and/or |
| convergence difficulties caused by the "Frozen Rotor" domain |
| interface : Impeller to Stator_2 |
| which could inject additional frequencies not captured by the |
| defined Fourier transformations. |
Details of error:-
Error detected by routine PEEKCA
CDANAM = CPERIOD
CRESLT = NONE
Current Directory : /ABR/OUTPUT/ZN1
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine MEMERR |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following user files have been saved in the directory
I already tried setting it as a large problem, switching to single instead of double precision, setting the memory allocation to 2 and to maximal and running it in serial instead of parallel. I tried all parallel run modes, changing various parameters in the simulation setup that could lead to a changing demands on the memory and changed the interface from the warning to "Transient Rotor Stator", just to see what happens. Nothing of that worked.
I'm looking forward to your help!
Edit: Could this possibly be a problem with the meshes?
zorgre is offline   Reply With Quote
Old   April 2, 2024, 15:04
Opaque will become famous soon enough
Details of error:-
CDANAM = CPERIOD
CRESLT = NONE
| Message: |
| has been created. |
You have a setup error where the period cannot be calculated. Review your model can compute the period for the transformation you have activated, or not have defined.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
memory, transient blade row
ERROR #001100279 has occurred in subroutine ErrAction. Sandeep Reddy CFX 3 May 22, 2019 19:58
Compiling User Fortran with CFX 14.0 on Win64 Raijin Thunderkeg CFX 29 March 9, 2016 12:45
"ERROR #001100279 has occurred in subroutine ErrAction ... no frame change model" darker2230 CFX 3 November 10, 2015 07:56
ERROR #001100279 has occurred in subroutine ErrAction. aniseh CFX 6 October 5, 2015 12:01
ERROR #001100279 has occurred in subroutine ErrAction. P9408 CFX 1 August 19, 2009 08:56
