March 24, 2008, 21:49 |
Hexa volume meshing
Hi all,
I'm currently a final year student undertaking a thesis project on a submarine. I'm new to ICEM CFD. I've been given a geometry (tetin, tin?) file with a blocking file. I need to create a Hexahedral mesh and transfer this to CFX. If anyone could give me any guidance or tips with this it would be much appreciated. I'm using version 11.0. Thanks, sam |
March 25, 2008, 06:50 |
Re: Hexa volume meshing
since you have geometry and block file in hand, you can pre-mesh the geometry and check the quality of the mesh to meet you require. then convert the mesh to nonstructure mesh. finally output to cfx.namely, click the output button,select the ansys cfx slover.
by the way,you can read the tutorial about this problem. |
March 27, 2008, 20:34 |
There´s a file on Emule in pdf format. Give a look there!
March 27, 2008, 20:37 |
the name of the file is "Ansys ICEM CFD 10.0 Manual.pdf"
March 28, 2008, 04:25 |
Thanks all for your responses. Greatly appreacited, thankyou.
[ICEM] Hexa meshing of impeller and diffuser assembly | Nitin Dewangan | ANSYS Meshing & Geometry | 14 | September 13, 2016 09:41 |
Error at Volume Meshing (Interface problem) | Trofrensis | STAR-CCM+ | 7 | December 27, 2009 15:54 |
Hexa Block meshes in ANSYS Meshing? | siw | ANSYS Meshing & Geometry | 3 | July 31, 2009 10:40 |
Meshing volume | Eduardo | FLUENT | 0 | March 15, 2006 13:20 |
volume meshing | nikita | FLUENT | 5 | June 30, 2003 05:11 |
