how to simulate 2d solid heat conduction using CFX
Old   March 20, 2008, 15:16
Default how to simulate 2d solid heat conduction using CFX
richard
Dear all,
I am looking at a steady 2-D heat conduction problem across a pipe wall with variable heat fluxes in the circumferential direction, heat flux dependent heat transfer coefficient on the outer pipe wall, and temperature-dependent thermal conductivity. I am wondering how to deal with the 2-D conduction in 3-D geometery? What should be the BC for the two end walls if the 3-D geometry must be solved. Any good examples for reference?
Thanks! Richard
Old   March 20, 2008, 18:55
Default Re: how to simulate 2d solid heat conduction using
Rogerio Fernandes Brito
I think u could use 1.000 mm (one millimeter) on the z direction and use the simmetry condition (on the same z direction) on cfx pre. donīt forget to make a comparison of your own model with experimental data before using the results for a real case founded on the industry,....
Old   March 20, 2008, 19:05
I suggest you will be able to utilize 1.000 mm (only one millimeter) on the z direction, using a condition of symmetry (on the same z direction) on cfx pre. donīt forget to make a comparison of your own model with experimental data before using the results for a real case found on the industry,.... I am so sorry, my english is getting worse on each day...
Old   March 24, 2008, 08:27
Default Thanks!
richard
Thanks Rogerio for your response! Regards, Richard
heat conduction in solid and convection in flow kunal FLUENT 3 February 29, 2012 05:42
Heat conduction through Sand or pulverised materials dwqi0419 CFX 6 May 26, 2010 05:53
Heat flux in ansys cfx juliom OpenFOAM Running, Solving & CFD 2 April 14, 2009 15:30
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
heat conduction in a solid francesco FLUENT 0 May 27, 2004 19:00
