Make line on curved boundary in CFXPost?
Old   March 19, 2008, 04:49
Default Make line on curved boundary in CFXPost?
andy2O
Dear All,
I have a curved surface within a heat transfer simulation. It is a domain interface boundary between a solid and fluid.
I would like to generate a line which lies on this boundary curved surface so that I can plot a chart of temperature and heat flux against position on the line. I also need to export the data on this line to Excel and interpolate it etc - that is why simple contour plots are no good to me here.
Can anyone tell me how I can generate a line on a curved surface in CFX to do this?
Many thanks for your help.
Andy
Old   March 19, 2008, 19:14
Default Re: Make line on curved boundary in CFXPost?
Rogerio Fernandes Brito
yes, it´s possible!
you have to create a polyline and also create a plane where you wanna make the extraction the points of heat flux and the temperature.
please, go to Tab "Location" on CFX-Post (ANSYS CFX-v11.0). You will use the method "boundary intersection"
Old   March 20, 2008, 04:20
andy2O
Many thanks - this worked well.
Yours, Andy
Old   March 20, 2008, 11:08
You´re welcome!
Old   March 20, 2008, 13:50
CycLone
Also have a look at the other Polyline creation options. If you have a contour plot, for instance, you can create a polyline for one of the contour levels.
-CycLone
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
