March 7, 2024, 08:32 |
Fatal overflow in linear solver.
夏锦霞
Rep Power: 3 |
I add a source to the Turbulence Kinetic Energy equation of the DES model,but after 500+ time steps ,CFX end with the error 'Fatal overflow in linear solver.',what can I do to solve the problem?
March 7, 2024, 08:57 |
#2 | |
Rep Power: 33 |
How did you implement the source? Without details, it is not possible to suggest modifications.
March 7, 2024, 09:37 |
夏锦霞
Rep Power: 3 |
I add a source to turbulent kinetic energy equation of DES model to make the model return to SST turbulence model,and then I can make use of Central Difference Scheme which can be only chosen in DES simulation.
March 7, 2024, 09:38 |
夏锦霞
Rep Power: 3 |
March 7, 2024, 10:30 |
Rep Power: 33 |
That describes your goal, but not how you attempted the implementation.
Each person can come up with different ways to code the modification, perhaps there is an error in your formulas or expressions. How can we tell? or something missing in the setup to complete the source?
des, modification, overflow |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 5 | November 22, 2024 07:32 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 07:33 |
Fatal overflow in linear solver and simulation never show convergence | Wong0912 | CFX | 1 | March 2, 2021 17:59 |
Fatal overflow in linear solver error. Why? | zaidun | CFX | 7 | August 11, 2016 06:59 |
2D isothermal cylinder not converging | UPengineer | OpenFOAM Running, Solving & CFD | 7 | March 13, 2014 06:17 |
