how do I get a solid volume moving?
Old   March 13, 2008, 12:17
Default how do I get a solid volume moving?
Katariina
Hello all!
This might be a trivial question but I am rather confused at the moment...
Say I have a large box and inside there is a small box. I'd like to get the small box "moving" in positive x-direction meaning that the box should stay put but it should get the fluid around it moving.
In Fluent this is done by saying that the small solid box has a motion type of "moving reference frame" and giving a value for its translational velocity. As a boundary condition the walls of the small box are given the correct velocity. This way the box itself isn't really moving anywhere but a boundary layer forms around it i.e. it induces movement in the fluid around it.
How do I do this in CFX??
Thanks in advance!
Old   March 18, 2008, 03:31
Default Re: how do I get a solid volume moving?
Sach
It is similar in CFX as that of in Fluent. Here it is MFR rather MRF, but the concept is same.
Just think in relatve velocity sense. For this you need to :
Additional setting need to be done when setting the domain to be moving domain (translating domain)
Old   March 28, 2008, 05:50
milosz
Doesn't MFR allow only rotational motion? I've been looking for some informations on transient simulations with moving meshes with large deformations but found nothing.
Moving Solid! shashank312 FLUENT 3 May 4, 2021 18:58
multiphase... solid volume fraction anomaly Tim CFX 4 February 14, 2012 05:01
[blockMesh] Solid volume inside computational domain francois OpenFOAM Meshing & Mesh Conversion 7 November 19, 2008 17:11
moving zone interface betw. 2 touching solid bodie Mike FLUENT 0 September 21, 2005 06:23
