LES near wall model & courant number
Old   March 13, 2008, 11:11
Default LES near wall model & courant number
kasim
Hi guys
I have two question:
1) Which wall model is used in LES for near wall modelling. Is it wall functions?
2) What is difference between average courant number and RMS courant number. In LES documentation they recommend courant number of 0.5-1 for LES, but i have Max courant and RMS courant during the run. No avearge courant number!
kasim
Old   March 13, 2008, 15:58
Default Re: LES near wall model & courant number
Andrew
Hi kasim
1. For LES i think normal wall functions are used.
2. I am not sure
Andrew
Old   March 13, 2008, 17:39
I do not agree with Andrew's comments.
1. In general you have to integrate LES models to the wall, so wall functions are not used. With the SAS/DES approach you can use wall functions in some places. This is a very technical area, I recommend you do some reading on wall modelling for LES before deciding which way to go.
2. A dedicated LES CFD code usually uses explicit numerics which limits the courant number to less than 1.0. CFX is implicit and can therefore converge on courant numbers greater than one. However you need to do a timestep independence study to determine what time step size is OK for your model.
Glenn Horroks
Old   March 14, 2008, 07:07
kasim
Thanks Andrew and Glenn. Glenn can you refer to me any literature that i can read on LES wall modelling. In documentation there is virtually nothing.
What is difference between RMS courant number and Max courant. How can one obtain average courant number?
Thank You Kasim
Old   March 16, 2008, 17:50
Here is some information for starters: http://www.cfd-online.com/Wiki/Near-...for_LES_models
Try the references from there.
The RMS is the root-mean-square (a type of average) but the max is the maximum value across the simulation.
Old   March 16, 2008, 19:23
kasim
Thank you Mr. Horrocks
Low Reynolds Number SST Model Josh CFX 41 June 4, 2023 20:00
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
