simple forced convection
Old   March 13, 2008, 10:10
Default simple forced convection
Al Mazdeh
Hi guys, I like to model a simple forced convection to evaluate cfx cs handcalc;
I have modeled a rectangular plate surronded by block of air.
I have defineda solid domain as Aluminim and fluid domain as air at 25 C.
I have defined inlet and outlet for air, and defined some heat load per volume on the solid domain .
now i want to make the solid-fluid intercation active.
so, I have defined a wall boundaries at the surfaec of my plate and the default option is set to adaibatic which ofcourase has to be other than adiabatic,
the other options ask for heatcoefiecnt or flux vaue which i do not know upfront somewher in the toturial they said u have o use flux conserved option when u have interaction betwwen solid and fluid like this case, but i can not find it
please help thanks
Old   March 13, 2008, 11:35
Default Re: simple forced convection
andy2O
You need to define a "domain interface" at the solid-fluid boundary instead of a normal boundary condition. So delete your wall boundary and look in the help system to find how to place a domain interface there - it is easy.
Once you do that the only option for the thermal boundary will be the "flux conserved" option you are looking for.
Good luck Andy
Old   March 13, 2008, 11:39
Al Mazdeh
thanks a lot
Very simple natural convection problem Naseem FLUENT 19 December 17, 2020 17:00
thermo settings for natural and forced convection braennstroem OpenFOAM Running, Solving & CFD 3 May 1, 2011 13:33
Forced convection Benchmark problem Raj FLUENT 0 January 28, 2009 07:10
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 05:58
heat convection in a forced fluid Daniele COMSOL 0 December 20, 2005 09:09
