March 13, 2008, 07:40 |
mesh independancy?
i've set a mesh which converged,but when refining the convergence was achieved ,is the problem a timescale kind or acually a mesh one. thanks |
March 13, 2008, 07:48 |
Re: mesh independancy?
Dear amine, it is hard to understand what whould you like to know.
both cases converged, so what is the problem? matej |
March 13, 2008, 08:22 |
Re: mesh independancy ?
my question was, i set a mesh that converged,when refining that mesh the solution didn't converge at least after a large timestep iterations & ocilated which wasn't the case previously. thanks |
March 13, 2008, 14:36 |
You are probably resolving details in the flow the prior mesh could not and these disturbances are affecting convergence.
March 13, 2008, 17:42 |
Craig is correct. Try using a larger physical timescale. Glenn Horrocks |
March 13, 2008, 18:05 |
I don't see the logic behind increasing timescale whenever you see oscillation. What if that oscillation is a real physical phenomenon? Using large timescale to get rid of oscillation just for sake of getting converged result is not always a good practice.
March 17, 2008, 17:41 |
I agree with you longbow. The full answer is work through the points on this link, of which increasing timescale is one: http://www.cfd-online.com/Wiki/Ansys...gence_criteria ps: I wrote this FAQ answer so I am well aware that there is more to it than just increasing the timestep! But I am a lazy typer so couldn't be bothered writing the whole thing every time somebody asks it. This question has been asked dozens of times so it gets pretty boring. Glenn Horrocks |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 09:07 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 14:40 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 05:49 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
