50% CPU usage
Old   March 12, 2008, 11:36
Default 50% CPU usage
AEsco48
Using Ansys 10 and CFX 10, i get a 50% cpu usage... Running an Intel T2250 @ 1.73 GHz Duel Core with 2.5gb of ram Windows XP Prof
Is it a setting thing or...?
Old   March 12, 2008, 12:15
Default Re: 50% CPU usage
Dre
When at the CFX-Solver, select Local Parallel instead of Serial for the Run Mode. Then select 2 partitions. This should utilize both cores.
Old   March 12, 2008, 12:30
AEsco48
PVV Local Parallel or MPICH Local Parallel for Windows
Thanks
Old   March 12, 2008, 12:42
Dre
Choose your flavor. I don't have extensive use with these. Maybe others will be able to chime in with their experience.
http://www.cfd-online.com/Search/cgi-bin/htsearch
Old   March 12, 2008, 13:27
Romeo
I am using intel core duo computer but i am working on academic license. Its not a license for parallel. Do you think i can still run my simulation on local parallel? If i can do i have to make a partition in mesh to run it on two processors separately.
By the way i tried to run it but it has given me an error. Is there a way out?
Romeo
Old   March 12, 2008, 13:38
Romeo
One more question. Is there a good web site or book to learn all about parallel processing. I dont know anything about parallel at the moment. Where do i start?
Old   March 12, 2008, 17:45
If you don't have any parallel licenses then you can only run single threaded. That means you will get 50% CPU useage on a dual core machine, 25% on a quad core.
The best information about parallel in CFX is the documentation. For information about parallel in general do a search on Google - good keywords would be MPICH or METIS.
Old   March 12, 2008, 21:26
Rogerio Fernandes Brito
Does CFX 11 use the 4 cores on Intel platform within Windows XP 32 bits?
Old   March 13, 2008, 17:44
If you use local parallel with 4 partitions it will. If you do a default serial run it will not.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
FloWorks and CPU usage? cvp_dk FloEFD, FloWorks & FloTHERM 6 June 20, 2011 09:57
How to max the CPU usage? Christoph_84 Hardware 2 June 8, 2011 16:45
CPU usage Echidna CFX 16 February 2, 2011 19:08
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 06:26
