Export data from CFX
Old   March 5, 2008, 10:33
Default Export data from CFX
J
Hi guys!
I have a question for you. I am working with aneurysms and, as you know, the geometry is quite complicated. When i export results, for example the velocity field in a section, i have in the output file a column vector with all the data. The problem is that, for example, if I would like to do a contour plot or a flooded contour plot, Matlab want a matrix (a rectangular matrix )...so...somebody can help me? Tecplot can do a contour plot with a column vector? (i have the coordinates of the nodes...)
Thanks guys!
J
Old   March 5, 2008, 11:15
Default Re: Export data from CFX
Nicola
Hi, import your file in tecplot as csv data file (no tecplot file) and then make a triangulation of your data. Then you can plot your data contour. If necessary cancel 1-6 lines of your file. Let only the line with variables without dimensions.
Regards
Export data in text file Eferal FLUENT 5 April 13, 2018 11:33
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 10:45
Export Results of CFX to Tecplot safikhani_hamed CFX 1 July 28, 2011 09:16
Export simulation data to 3d mesh dlugi OpenFOAM 0 May 19, 2011 05:47
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
