Discontinuity in contours over periodic interfaces |
January 29, 2024, 16:23 |
#21 | |
Rep Power: 2 |
However, I found it was very very difficult to have exact same nodes on both periodic surfaces between two different rotor fluid domains. I found that the edge size difference is in the order of 5 digits (10e-5) and it is very hard to control that small number. Hope that I address the issue clearly. |
February 14, 2024, 17:29 |
#22 |
Rep Power: 2 |
I created the geometry in NX, and found out that the periodic surfaces have very little area difference about ~0.05 mm2. No matter how I tried, I was not able to make identical surfaces on both sides.
February 14, 2024, 17:43 |
#23 |
Rep Power: 144 |
In ICEM you should be able to edit the meshes to make it identical, if that is what you want to do.
February 14, 2024, 22:28 |
#24 |
Rep Power: 2 |
February 14, 2024, 22:51 |
#25 |
Rep Power: 144 |
Go in ICEM generate a surface mesh on one of the surfaces, transform it over to the matching surface, associate it to that surface, and then generate the volume mesh with those two matching surface meshes pre-defined.
Alternately, you could use the mesh joining function: Do a volume mesh as normal, then make a copy of the mesh transformed across so the periodic faces match up. Do a merge mesh on the matching face, then delete the transformed mesh. There's two ways I can think of how you can make ICEM make a matching mesh on those faces.
February 14, 2024, 22:56 |
#26 | |
Rep Power: 2 |
When I said two airfoils, they are different ones. So, the meshes for two separate fluid domains should be generated individually in ICEM then they are loaded in CFX. |
February 14, 2024, 23:12 |
#27 |
Rep Power: 144 |
The two methods I described can be adapted to make matching meshes for two domains with different airfoils but matching periodic faces as well.
February 14, 2024, 23:16 |
#28 |
Rep Power: 2 |
But I'm not trying to make them as one fluid domain. It is necessary to have them as separate mesh files and fluid domains. Because there are various configurations of those two airfoils; sometimes they are neighbouring, sometimes not.
February 14, 2024, 23:27 |
#29 |
Rep Power: 144 |
Yes, so you take one mesh file, load the other one, make the face mesh match and then delete the second one.
February 14, 2024, 23:31 |
#30 |
Rep Power: 2 |
Okay. Let me try that. So is this the first method or the second one?
If possible, can you explain the steps in detail again? |
February 14, 2024, 23:34 |
#31 |
Rep Power: 144 |
The loading both meshes then deleting one mesh could be applied to both approaches I mentioned earlier.
If you have not used the mesh edit functions in ICEM before I recommend you do a bit of testing before you start with your real geometry. Make a block and try meshing a few surfaces and using these surface meshes, and also test the mesh merge functions. When you understand how the functions work on a simple test geometry then try your actual geometry.
cfx, icem cfd, periodic interface, turbomachinery |
Discontinuity across interfaces | Nurzhan | CFX | 2 | March 11, 2015 02:59 |
[ICEM] how to define periodic in icem ? | mingersai | ANSYS Meshing & Geometry | 1 | February 3, 2012 18:46 |
discontinuity of solution due to interfaces ? | T.D. | OpenFOAM Running, Solving & CFD | 4 | December 20, 2010 10:42 |
Discontinuity through periodic boundaries | mighelone | FLUENT | 0 | May 26, 2010 12:53 |
Discontinuous contours on R/S interfaces | Rikio | CFX | 3 | September 15, 2008 15:21 |
