hi
i going to buy a new PC,& talking about hardware i'm not strong !, so: does the new intel core2 quad really 2 times faster then the core 2 duo? does 4 Go memory ( 2x2 Go) better then 4x1 Go ? is there any equivalent to the intel QUAD for AMD? |
Intel Xeon Workstation. How about it?
is the intel xeon the best on the market ( better than the core 2 quad)?,it's a two core too ?isn't it?
If you have a commercial license the cost of the licenses far exceeds the hardware cost. Therefore you need the fastest CPU you can get on a single-process basis. At the moment that is Intel Woodcrest 5160 CPUs but these are being overtaken by the latest update by Intel, I think the 6850 is a little faster and other one just released is faster still. If you are on an academic license then the equation is a bit different as the license costs are far cheaper. If you are using a pirated license then this conversation will cease here! Glenn Horrocks |
i donīt know about what you said, but Intel Xeon processors is apropriated to running problems like that during many days, for example, without stopping!
Looking for a pimpleFoam tutorial using Salome (and hardware recommendations?) | madact | OpenFOAM | 1 | May 27, 2010 01:24 |
Hardware recommendation? AMD X2, Phenom, Core2Duo, Quadcore? | rparks | OpenFOAM | 0 | April 22, 2009 09:10 |
Hardware Recommendation for Parallel Processing | Brian Bian | CFX | 2 | February 7, 2006 17:27 |
hardware for fluent | Christian | FLUENT | 9 | December 3, 2001 16:05 |
hardware | Guus Jacobs | Main CFD Forum | 24 | May 3, 2000 16:42 |
