March 2, 2008, 09:57 |
Incompressible
Hi, I want to simulate laminar transient flow with air. I want to use temperature independent flow properties and constat density. Air at 25 work here? Also the energy would be total or thermal?
Thanks, --Selim |
March 2, 2008, 12:59 |
Re: Incompressible
For the incompressible solution, you will use the option of isothermal and use 25C as temperature with the laminar flow model.
Good Luck. |
March 2, 2008, 13:03 |
Re: Incompressible
My problem involves heat transfer I want to use temperature independent material properties. Thanks, --selim
March 2, 2008, 18:00 |
Re: Incompressible
just choose laminar flow, if you have low values of velocities! Try calculating the Grashof number (if you have natural convection) or Reynolds number (if you have forced convection).
March 2, 2008, 18:04 |
Re: Incompressible
donīt you forget to make a validation of cfx software with experimental data! I recommend you using hexa mesh!
Incompressible turbulence models: strange implementations? | AleDR | OpenFOAM | 3 | November 18, 2014 12:23 |
Hardware selection for steady/unsteady incompressible, turbulent and cht simulations | maddalena | OpenFOAM | 2 | July 13, 2011 09:55 |
Incompressible Ideal gas law | Leverkin | FLUENT | 5 | March 5, 2009 17:41 |
Abt: the speed of sound in incompressible flows | jinwon park | Main CFD Forum | 3 | August 21, 2008 21:44 |
Compressible vs. Incompressible formulations | Fernando Velasco Hurtado | Main CFD Forum | 3 | January 7, 2000 17:51 |
