Change Catalogue Size Multiplier Parameter
Old   February 29, 2008, 13:49
Default Change Catalogue Size Multiplier Parameter
ahlo
I used to change this number from CFX solver manager, but it hinders me to make batch processing. Is there any way to make it within CFX-pre setting or by scripting?
Thanks
Ahlo
Old   March 3, 2008, 05:21
Default Re: Change Catalogue Size Multiplier Parameter
Pankaj
Dear Ahlo!
You need to edit it through command editor. Right click on simulation in cfxpre,edit in command editor,Copy and paste 'Catalogue Size Multiplier = 2'(do not use inverted comma)in solver control section.
This must work.
Regards, Pankaj.
Old   March 5, 2008, 14:39
ahlo
Hi Pankaj,
Following your indication, I inserted
Catalogue Size Multiplier =2
behind SOLVER CONTROL:
and click "Process" Button and then "Close" Button
Then I save again this .cfx file. When I open the file again, it seems that this line is not saved within the .cfx file. Is it possible let .cfx file remember this new line?
Thanks
Ahlo
Old   March 6, 2008, 01:30
Pankaj
Dear Ahlo,
First tell me whether your problem of catalogue size has been solved?
If solved,then just add the line in solver control,export one ccl file (which can be read through notepad)from CFX pre.Then every time import mesh,ccl file and go ahead.
I think this must work.
Regards, Pankaj.
Old   March 6, 2008, 12:06
ahlo
Hi Pankaj
This CCL approach works well. Thank you
Ahlo
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 12:22
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
INSUFFICIENT CATALOGUE SIZE xfshi CFX 3 June 11, 2003 15:16
File Catalogue Size Jesper CFX 2 December 3, 2002 06:03
