ICEM Tetra Speed
Old   February 27, 2008, 04:55
Default ICEM Tetra Speed
Vikram
I need some help on the speed of ICEM Tetra on a Windows XP 64 bit machine. I find that whenever I start the meshing process, CPU usage shown in the task manager is very low and the mesh generation takes a lot of time. I know it has something to do with settings in ICEM but if someone can share their experience on this it will be really nice.
Thanks in advance. Vikram
Old   February 27, 2008, 17:32
Default Re: ICEM Tetra Speed
It probably means your machine has run out of RAM and is using the page file. This will be very slow compared to the same task in RAM.
How much RAM do you have and how big is the mesh?
Old   February 28, 2008, 01:28
Vikram
Hi Glenn,
The RAM is 4 GB dual processor and the mesh size is some 2 million. There are clearance gaps and ribs to cope with.
But ICEM Tetra has an option for 2 processor usage. We can select 2 processors in the general settings menu. This speeds up the mesh generation to quite an extent.
Thanks, Vikram
Tips of ICEM CFD meshing speed up CFD_D_BOY ANSYS Meshing & Geometry 1 September 7, 2011 03:53
ICEM Tetra mesh, Size reduction and Skewness problem Catthan ANSYS Meshing & Geometry 6 December 5, 2010 20:39
ICEM, Tetra removing Mikhail CFX 1 July 24, 2008 12:07
Icem tetra - Running in parrallel? Joe CFX 5 September 9, 2006 13:37
ICEM CFD 5.1 problem with tetra count Baskaran CFX 2 March 13, 2006 13:59
