2D modelling using CFX
Old   February 26, 2008, 06:31
Default 2D modelling using CFX
Wei-Haur Lam
I would like to model a Darriues wind turbine with straight blade. I am interested at the velocity field around the wind turbine and the wash at the downstream of wind turbine.
This case can be simplified to be a 2D case. However, according to the information I know, CFX does not provide a 2D modelling. Is this true? If it is, any alternatives to model this case in 2D?
Thanks.
Old   February 26, 2008, 07:41
Default Re: 2D modelling using CFX
andy20
Please see the FAQ for this forum:
http://www.cfd-online.com/Wiki/Ansys...tion_in_CFX.3F
Regards, Andy
Old   February 26, 2008, 08:54
kirby
you should generate one layer of mesh in the third direction. and you should not to solve the parameters of this direction.
Old   February 26, 2008, 09:50
Wei-Haur Lam
The FAQ states,
"... For a 2D planar simulation this would be one element in the normal vector direction ... In CFX-Pre you should set the top and bottom faces of the extrusion as symmetry planes.."
I have extruded the mesh in the normal direction with one or few elements. In addition, I have set the top and bottom faces of the extrusion as symmetry planes. However, the changes of element in the normal direction provide different results. How to obtain a consistent result?
Thanks.
Old   February 26, 2008, 17:45
For a 2D planar simulation the extrusion in the normal direction is one element only, and the top and bottom faces must be parallel.
Old   February 27, 2008, 14:04
Wei-Haur Lam
Hi Glenn,
Can I ask you a further question? If I would like to control the running time within a day for a rotating case using a sliding mesh method with fine time step (approximate 2 million cells), how much computational demand is required in term of number of processor and RAM for a computer cluster?
Thanks
Old   February 27, 2008, 17:52
Memory estimates for simulations is discussed in the CFX documentation.
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 15:22
Modelling Bingham in CFX 11.0 Dirk CFX 6 March 12, 2009 08:42
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 15:01
Reg : Modelling of Gasification Using CFX S.SIVAKUMAR CFX 0 June 4, 2008 04:47
