finding drag and lift force
Old   February 26, 2008, 02:13
Default finding drag and lift force
Deloat
Hi all,
Does anyone knows how to view the time history plot of forces, such as drag and lift force? I managed to solve my transient simulation of flow past cylinder, and right now i want to figure out the forces acting on the cylinder body.
Is there a way to find the total force acting on the body over the time steps that i had done?
Thanks in advance, Deloat
Old   February 26, 2008, 06:03
Default Re: finding drag and lift force
Generate a CEL expression to calculate lift and drag forces. Send the expression to a monitor point. Redo the simulation and the data will be visible for every timestep (and every iteration inside a timestep if you like) in Solver Manager.
Old   February 26, 2008, 19:20
Deloat
Thanks for the reply,
But if i want to find the resultant drag force for a particular timestep, is there such CEL expression to do it? or it can only find the force of a point.
Thanks, Deloat
Old   February 27, 2008, 17:53
Look in the CFX reference manual under the CEL reference manual. It gives a list of available functions. The function you are looking for is force_x, force_y, force_z.
drag force and lift force? davoodsae CFX 1 October 4, 2010 19:02
CoL, Lift force, CoD, Drag Force Echidna CFX 3 June 18, 2010 06:59
Lift and Drag force coefficients vkrastev OpenFOAM 0 January 28, 2010 18:04
Lift and drag force Arti Main CFD Forum 0 April 23, 2009 23:46
how to set lift and drag coefficients in force mon alagesanj FLUENT 0 November 16, 2008 21:47
