How to find Heat Transfer Co-efficient (HTC)? |
February 23, 2008, 20:42 |
Dear Friends,
Could you please tell me how to get HTC (Heat Transfer Coefficient) in CFX out put results? I would like to know whether CFX can give HTC values of an object if it dissipates power in natural of forced air convection. Thanks a lot for your time! |
February 24, 2008, 06:56 |
Re: How to find Heat Transfer Co-efficient (HTC)?
If I can remember correctly, you can't. You'd have to create a function with the definition of the HTC.
February 24, 2008, 16:41 |
Thiago - you are incorrect. CFX has the HTC as a variable in the results file for a simulation with heat transfer. To access it you have to click on the "..." button on CFX-Post. Also, note the HTC is referenced to a "far" temperature. By default the far temperature is the variable (I think this is its name) "wall adjacent temperature". You can use a expert parameter to fix this far temperature to any value you like for comparison to published data. Glenn Horrocks |
February 24, 2008, 16:52 |
Alright, sorry about that and thanks for pointing out.
February 24, 2008, 19:57 |
Dear Thiago Queiroz and Glenn Horrocks,
Thanks a lot for your reply. |
March 4, 2008, 13:20 |
hai,
how to find out the heat transfer co-efficient by natural convection equipment(fabrication method).please mail me immediately. |
calculate heat transfer coefficient in repeated geometry | mullenc525 | CFX | 4 | January 24, 2017 14:30 |
Modelling the heat transfer during compression and cooling of natural gas | pano | Main CFD Forum | 0 | December 10, 2010 15:53 |
Heat Transfer in Porous Medium | eryan | STAR-CD | 0 | September 28, 2010 13:14 |
Conjugate heat transfer problem | hvem10 | FLUENT | 2 | October 29, 2009 17:31 |
CFX Heat Transfer | RJamison | CFX | 0 | July 24, 2008 12:11 |
