Sub domains?
Old   February 22, 2008, 14:59
Default Sub domains?
Chris Wetton
Hi, i have a question regarding a model i am trying to build in cfx. Basically I am modelling the dam break problem using a VOF method. The basic models are running ok, however i am now trying to simute the DBP using 2 volumes of water (ie the large normal volume and a smaller volume which will be encompased when the larger volume collapses). My "gut" feelings would be to use a subdomain, but I have never used these before. Is this the correct way of doing this or does someone know of a better method. thanks Chris
Old   February 24, 2008, 17:47
Default Re: Sub domains?
Why are subdomains required? A subdomain may be useful to define the initial condition.
Coupled domains with two different fluids General_Gee OpenFOAM Running, Solving & CFD 3 October 11, 2010 13:51
Meshing Multiple Domains at Once ! rvallejo ANSYS Meshing & Geometry 1 June 19, 2010 22:49
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 16:20
buoyancy in two separate domains DenizeN FLUENT 0 January 16, 2008 16:33
Multiple domains - buoy. ref. temp. setting Forrest CFX 8 February 22, 2006 14:43
