February 21, 2008, 08:30 |
Non-dimensional timestep
Hi, can anybody tell me how the non dimensional timestep is calculated? What does it mean by non dimensional timestep of delt=0.004 or else?
February 21, 2008, 17:48 |
Re: Non-dimensional timestep
Where do you get a non-dimensional timestep? CFX uses dimensional timesteps. Glenn Horrocks |
February 22, 2008, 03:45 |
Hi Glenn,
Thanks. I know that Cfx uses dimensional timesteps. But, from some literature, I found that they used non dimensional timesteps and I wanna compare my used timesteps in cfx(dimensional) with their non dimensional timesteps. Thats why I wannna convert this dimensional timesteps to non dimensional timesteps. |
February 22, 2008, 11:56 |
The 'non-dimensionalisation' of a problem, and hence the calculation of a non-dimensional timestep is 100% problem dependent. There is no general rule.
It might be related to (typical length)/(typical speed), but it might also be based on a diffusion timescale, or a number of other possibilities. You will need to look at the literature you are interested in and see if that describes the choice of timestep used by the authors. If it does not, then you may have to contact the authors directly. So, unfortunately we cannot give you an answer. Good luck, Andy |
February 24, 2008, 17:16 |
In addition to what Andy said, you can always convert the dimensional timestep reported by CFX to a non-dimensional timestep simply by applying the non-dimensionalisation for the time variable. Most non-dimensional schemes generate some form of reference time, then the non-dimensional timestep is simply dimensional timestep/reference time. Glenn Horrocks |
Restart 2-way FSI with different timestep? | Lance | CFX | 10 | April 17, 2013 00:37 |
Adequate timestep selection for multidomain problem | gerardosrez | CFX | 6 | November 28, 2010 17:50 |
Timestep study | ijk | CFX | 6 | April 9, 2010 07:38 |
interTrackFoam timestep | virginie_e | OpenFOAM Running, Solving & CFD | 4 | April 6, 2009 05:02 |
Use of Timestep in obtaining solution. | hagupta | CFX | 7 | February 28, 2006 13:14 |
