Unrealistic Pressure and Vapor Field during Cavitation Simulation |
November 1, 2023, 01:53 |
Can Unsal
Rep Power: 7 |
Hello All,
I need to simulate the vapor formation inside of the piston as it moves and sucks fluid from a throttle. The problem is, the solved pressure and vapor fields are pretty random and unrealistic. Vapor is being formed at irrelevant locations. The simulation domain is shown at the attachments and here is a brief description. -On the right hand side "Opening" with 3 Bara is defined. Only the liquid entrance is allowed. (Liquid Phase Fraction: 1, Vapor: 0And here are the what have i tried and didn't worked so far. -Simplified the model and created mesh with better quality (All hexa)Those are the things that did not worked. I need to calculate the vapor content and vacuum pressure inside of the piston. Thanks in advance for your helps. |
November 1, 2023, 05:41 |
Rep Power: 144 |
Can you post your output file, and an example image of what you are getting? You might also need to post an image showing what your boundary and mesh domains are if that is not obvious.
