optimizating flow (staticmixer tutorial)
Old   February 20, 2008, 23:58
Default optimizating flow (staticmixer tutorial)
mike
I am following the static mixer tutorial and when I load up the design explorer the only parameter's i can modify are the velocity inlets. I want to be able to modify the geometry. I did check the bock in design modeler to indicated a parameter. Is there something I missed?
Old   February 21, 2008, 00:57
Default Re: optimizating flow (staticmixer tutorial)
Dre
I've had this same problem, but with a structral simulation, so I hope this works!
Try this :
When in the project tab of Workbench
-Select the geometry once -look to the left under "Default Geometry Options" and delete the "DS" in the Parameters box.
This should publish the parameter for use in DesignXplorer.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Fluent tutorial for turbulent flow Jenner FLUENT 8 December 12, 2006 04:26
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
