CFX 2D ANALYSIS BOUNDARY CONDITION
Old   February 19, 2008, 11:42
Default CFX 2D ANALYSIS BOUNDARY CONDITION
fat bug
I found out that the way to do 2d analysis in CFX is to make 1 layer extruded mesh. The documentation of CFX says we can use something like a 20° Portion of a axisymetrical model. My question is, when setting up boundary condition in this case, should I still do a inlet volume flow rate and divide the original number by 9 (according to the model size), or would I have to use the velocity as boundary condition.
Thanks!
Old   February 19, 2008, 17:22
Default Re: CFX 2D ANALYSIS BOUNDARY CONDITION
Don't use a 20 degree portion, use a portion less than 5 degrees, or 1 or 2 degrees if you want to be super-accurate.
Yes, you need to scale mass flows by the ratio of the inlet sector to the full real inlet area. For a 2 degree sector the scale factor is then 180.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 11:54
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
CFX 5.5 Boundary condition Veebs CFX 5 May 19, 2002 21:55
