[CFX-Post] Force over time
Old   February 18, 2008, 08:39
Default [CFX-Post] Force over time
RNE
Hi folks,
I'm novice with CFX and I'm trying to produce a chart (or table) in CFX-Post which renders the force acting on a surface over time. However, It seems that CFX-Post is only able to compute such quantity using the "Function calculator" for each time snapshot. I already tried to configure a chart, but I can't select the desired surface on the location combo box. Any ideas?!
Thanks in advance.
Old   February 19, 2008, 13:26
Default Re: [CFX-Post] Force over time
KB
Ever tried a Time Chart?
Old   February 19, 2008, 13:32
RNE
Yes, I tried a Force x Time chart but CFX-Pro don't let me choose where (surface region) the Force should be integrated on. Actually, this is my main problem?
Regards
RNE
Old   February 19, 2008, 13:57
UnderwaterAlex
Create an expression in post that is the force integration over the surface (for instance: areaInt(Pressure)@Body or whatever force integration you need) and then plot a time chart of that expression.
-Alex
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Force can not converge colopolo CFX 13 October 4, 2011 23:03
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 13:32
