ANSYS Workbench on "Uncertified" Linux Distros |
February 24, 2011, 10:48 |
#121 |
Nikolopoulos Aristeidis
Rep Power: 15 |
There are to many!!!!
February 24, 2011, 10:53 |
#122 |
Vadim
Rep Power: 15 |
February 24, 2011, 10:55 |
#123 |
Vadim
Rep Power: 15 |
February 24, 2011, 11:05 |
this code doesn't seem to do anything...
#124 |
Rep Power: 15 |
However:
/lib/ld-linux.so.2 doesnot exist lib folder doesn't have such files. in /lib64 there is a ld-linux-x86-64.so.2 I appreciate your help! |
February 24, 2011, 11:27 |
#125 | |
Vadim
Rep Power: 15 |
# ln -sf ./ld-linux-x86-64.so.2 ./ld-lsb-x86-64.so.3 |
February 24, 2011, 11:36 |
#126 |
Rep Power: 15 |
I solved the problem
yum install glibc.i686 but now i have the same problem with libstdc++.so.6 |
February 24, 2011, 11:45 |
#127 |
Vadim
Rep Power: 15 |
February 24, 2011, 11:54 |
#128 |
Rep Power: 15 |
I installed redhat -lsb package but still libstdc++.so.6 is not available
February 24, 2011, 12:22 |
#129 |
Vadim
Rep Power: 15 |
February 24, 2011, 12:29 |
#130 |
Rep Power: 15 |
i did it. but glibc.x86_64 is already installed!!!
When i remove glibc.i686 the problem with ld-linux.so.2 occurs again |
February 24, 2011, 12:38 |
#131 | |
Vadim
Rep Power: 15 |
Also you could need to make such simlink: Code:
# ln -sf /lib64/ld-linux.so.2 /lib/ld-linux.so.2 |
February 24, 2011, 12:56 |
#132 | |
Rep Power: 15 |
I removed i686. I made ln command and the file was copied. However i get the message copying necessary files to /tmp/ans_install_tmp7323/ Executing /tmp/ans_install_tmp7323/instcore /tmp/ans_install_tmp7323/INSTALL: /tmp/ans_install_tmp7323/instcore: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory How i make simlink? Thank you for your time and effort! |
February 24, 2011, 13:09 |
#133 | |
Vadim
Rep Power: 15 |
What`s a platform-version of your Ansys-package? |
February 24, 2011, 13:11 |
#134 |
Rep Power: 15 |
It is ANSYS13.0 for Linux 64.
I'm using Fedora 14 (64bit) |
February 24, 2011, 13:33 |
#135 |
Vadim
Rep Power: 15 |
So, that does mean you can solve the problem by making
symbolic link of /lib64/ld-linux-x86-64.so.2 to /lib64/ld-lsb-x86-64.so.3 and second of /lib64/ld-lsb-x86-64.so.3 to /lib/ld-linux.so.* There are no more troubles. |
February 25, 2011, 06:39 |
Thanks!
#136 |
Rep Power: 15 |
I installed fluent!
but now when i run fluent this problem occurs: /usr/ansys_inc/v130/fluent/fluent13.0.0/lnamd64/3ddp/fluent.13.0.0: error while loading shared libraries: libiomp5.so: cannot enable executable stack as shared object requires: Permission denied The fluent process could not be started. Do you have any idea? |
February 26, 2011, 18:42 |
Ansys 13 and license manager
#137 |
Phoevos
Rep Power: 17 |
Hi to everyone,
I would like to share my experiences trying to use ansys 13 on linux (Ubuntu 64 8.10 to be more specific), since they might help others. So on my ubuntu 8.10 x64 pc, I had already installed ansys 12 and set up the license server etc. Fluent and CFX components of ansys 12 worked as they should (serial & parallel) - since I am more concerned on CFD I only tried cfx and fluent, also I never liked workbench. Today I decided to install ansys 13. Even if I tried the method described in page 5 of the current thread (I created the rpm and uname commands, commented out the second entry of MYHOSTNAME in etc/hosts, .....) I was still unable to connect to the license server, getting the same message as Siden (check at page 5 of current thread), namely : couldn't execute "/ansys_inc/shared_files/licensing/linx64/lmutil": no such file or directory I tried to execute lmutil from terminal to see what happens, but got the same response. Thinking that the lmutil might got corrupt somehow (?), I replaced it with the old lmutil from the old license manager of Ansys 12. Well now I was able to connect to the server, identify my license and start the licensing interconnect and the licensing interconnect monitor, the FlexLm however didn't start. Of course neither Fluent nor CFX started (12 or 13), giving me various responses from 'could not connect to license server' to 'segmentation fault' (!). Reverting to the old License manager solved the problems, but only for the old Fluent and CFX (12), the new ones requested the new version of the license manager. So what I did was to replace the executables/files of the new license manager located at .../ansys_inc/shared_files/licensing/linx64 with the old executables/files of the Ansys 12 license manager apart from the ansyssli_server executable, which is neccessary for the new program versions to run. Well then all license manager components worked and, at last, both CFX and Fluent (12 and 13, including CFX pre, Solver and post) ran without errors, as long as I tried, serial and parallel ! I have tried to run workbench too using the script 'runwb2' at '/ansys_inc/v130/Framework/bin/Linux64/' but it didnt work, I got the following errors in terminal : QPainter::setFont: Painter not active QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread QPixmap: It is not safe to use pixmaps outside the GUI thread as already encountered by makkemal and Yankee (page 5 same thread). I have not tried the solution Yankee proposed, but I dont really care about workbench, I am happy fluent and cfx work. To conclude I think that an important part of the trouble is the new license manager. My solution is rather cumbersome, since you need to mix the two license managers, but at least works for me. |
February 28, 2011, 14:25 |
How to install ANSYS 13 on RHEL 6.0 x64 Workstation?
#138 |
Karl Scmied
March 7, 2011, 13:30 |
#139 |
Rep Power: 15 |
March 8, 2011, 06:20 |
#140 |
Phoevos
Rep Power: 17 |
LINUX Experts: Help with installing ANSYS workbench | faisal_durr | ANSYS | 1 | May 30, 2014 09:07 |
Ansys workbench problem | Jonny6001 | ANSYS | 2 | September 30, 2010 13:59 |
How can I start the ANSYS 12 workbench in LINUX | Ardisia | ANSYS | 3 | September 7, 2010 01:19 |
ANSYS Workbench on Linux | CPUcruncher | ANSYS | 4 | July 11, 2010 10:19 |
ANSYS Workbench on "Certified" linux distro | mechanicaldesign | CFX | 0 | April 16, 2010 02:56 |
