ANSYS Workbench on "Uncertified" Linux Distros
Like Tree26Likes
Old   January 14, 2011, 11:43
fabio moretti
fabio moretti is on a distinguished road
Hi everybody
This is my first appearance on this forum, I apologize in advance should I be missing something important. And thank you for sharing your ideas, problems and solutions.
Scott Johnson:
It seems I have the same troubles as you have, I mean the CCL errors.
I installed ANSYS CFX 13.0 on a Fedora 13 x86_64 desktop, with an nvidia display adapter (the driver being the one provided by fedora).
After some iterations (requiring some yum installs) I got to a complete install without error messages. The problem arises when trying to define a new case with CFX-Pre, as well as when simply closing CFX-Pre GUI.
By the way, I also installed the code on a Fedora 8 server, where it runs fine; on the other hand I would like to abandon such distro because it gives me troubles with other software packages.
Have you got any good news? Thanks.
Regards to you all
fabio
fabio moretti is offline   Reply With Quote
Old   January 14, 2011, 18:10
Charlotte
charlotte is on a distinguished road
As I posted before, I didn't get any luck with Ubuntu/CAELinux (CCL errors). Too bad, I wanted to play with CAELinux a little bit, but I guess it will be for another time.
I made a clean install with OpenSuse 11.2 64bit and install Workbench/CFX without trouble (installing my graphic card was much more painful...). Everything is working: DM, Mesh, CFXPre, CFXsolver & CFXPost.
charlotte is offline   Reply With Quote
Old   January 17, 2011, 08:36
ginggs is on a distinguished road
Originally Posted by makkemal View Post
Ubuntu 10.04
With the steps above 12.1 runs fine
in 13 I get the following errors on the same machine
QPainter::setFont: Painter not active
QPixmap: It is not safe to use pixmaps outside the GUI thread
Anyone seen this
Thanks
M
I had exactly the same problem; 12.1 runs fine but 13.0 not starting. Thanks to this thread I removed ~/.ansys and ~/.config/Ansys and the problem was solved.
ginggs is offline   Reply With Quote
Old   January 17, 2011, 10:16
ffg
surfer
ffg is on a distinguished road
I have ubuntu 10.10 64 bit and I followed all the instructions given by yankee to install Ansys 12.1 . Only one difference: I used the noroot flag to install the software. Ansys workbench starts, the Design Modeler starts but it doesn'tt work. The interface starts but I can't do anything and if I try to close it it gives a "script error" on a little windows and the "workbench error: error connecting to albion"; in the starting shell. ( The same steps on a ubuntu 9.10 64 bit lead to a successful installation. All works). Any idea? ffg
ffg is offline   Reply With Quote
Old   January 17, 2011, 11:29
I think this may be the solution for you:
ANSYS expects to find libGL.so.1 in /usr/lib/.
The following solved my problem:
For Nvidia drivers
sudo ln -s /usr/lib/nvidia-current/libGL.so.1 /usr/lib/libGL.so.1
For Mesa drivers
sudo ln -s /usr/lib/mesa/libGL.so.1 /usr/lib/libGL.so.1
Old   January 17, 2011, 11:30
Yves Delannoy
Yankee is on a distinguished road
I experienced this "workbench error: error connecting to albion" when my /etc/hosts file had twice the name of my machine on two uncommented lines. I edited it, commented the second one (which was related to ipv6), and all trouble was gone.
The only difficult point is that, at least on laptops changing regularly their network configuration, the networkmanager re-inserts regularly this double declaration in /etc/hosts . A web request indicates that this is a known behavior of network manager, which seems not considered as a bug. To avoid it you can make /etc/hosts immutable (with the chattr command) or modify your workbench script to comment the second one automatically (but I only find a solution with sudo, that asks your password each time).
Yankee is offline   Reply With Quote
Old   January 17, 2011, 11:48
ffg
surfer
@ginggs
I have the nvidia driver 260.19.29 and libGL is already linked to that.
@yankee
that was it!!! I thought I had all my hostname removed but one, but I had this line
::1 hostname localhost6.localdomain6,localhost6
that caused the trouble. commented the line and design modeler works !!!
Thank you very much ffg
Old   January 17, 2011, 14:12
Rafael Oliveira
rafasdo is on a distinguished road
I would like to express my thanks to everyone for your contributions. I did make the instalation of ansy13 in Ubuntu 10.10 x86_64 following the steps of Yankee and now everything is working: DM, MESH, Fluent. Below is some information that might be useful:
1º I installed the pack: ia32-libs
2º file /etc/hosts: I did make as proposed, but appear the err: "RPCSS ServiceMain failed with 1702 (000006a6)'. To solve the problem I left the file hosts as follows:
127.0.0.1 hostname.domain hostname localhost.localdomain localhost
# The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
3º libGL: Before of create a link to libGL library, i used the command to find it:
find /usr -print | grep -i "libGL.so.1"
rafasdo is offline   Reply With Quote
Old   January 20, 2011, 15:42
Scott Johnson
Scott Johnson is on a distinguished road
Similar to Charlotte, I also moved to a different distro after failing to fix the CCL errors in Ubuntu on my new machine. I installed CentOS 5.5 and everything is also working.
In configuring all the hardware and installing the software I need on CentOS, I am reminded why I moved to Ubuntu several years ago. I sure wish I could have been able to resolve the CCL errors.
Scott Johnson is offline   Reply With Quote
Old   January 25, 2011, 08:44
Default Ansys WB on fedora 11 x86_64
  #110
Martin Nesladek
rasov24 is on a distinguished road
Hello!
Is anybody here who was able to run successfully Ansys WB 13.0 on fedora 11 x86_64? For me, installation went smoothly. After that I only found some warning message in install.err which is following:
ANSYS installation: Mon Jan 24 16:41:22 2011
Revision: 13.0
   Warning!
   Host name lookup failed for host "myhostname"
When I run WB through /ansys_inc/v130/Framework/bin/Linux64/runwb2 everything seems correct till I try to start DM, meshing or some other module. After some time of playing I got these messages in terminal:
Aborting due to unexpected error:
hostError: Socket::connectHostPort - gethostbyname - HOST_NOT_FOUND: Authoritative Answer Host not found
Warning: token %1 was not used in the message: "socketError: Socket::waitForConnection - Connection timeout after 120s"Warning: token %1 was not used in the message: "socketError: Socket::waitForConnection - Connection timeout after 120s"Aborting due to unexpected error:
comm::error: AppWindow::initialize - Error waiting for viewer connection from engine:
The application has encountered an unexpected problem and will now terminate:
Please report this error, along with the circumstances in which it occurred.
The following information may be useful to CFX support:
Unexpected error: Aborting due to unexpected error:
Warning!
CFD-Post exited with return code 3
I am not sure if the above message is related to lack of license tokens or something else (I am new to this software). But the biggest problem is DM and meshing don't want to start...
Of course I have read previously suggested solutions that work for Ubuntu or Debian. But in fedora some of them cause other problems in the system without helping with WB (for example, if I add /ansys_inc/v130/Framework/bin/Mesa or
/ansys_inc/v130/Framework/bin to LD_LIBRARY_PATH).
Any suggestions? Thanks in advance!
Martin
rasov24 is offline   Reply With Quote
Old   February 2, 2011, 05:22
Default wb13 on both ubuntu 10.10 and fedora 12
  #111
ffg
surfer
I installed ansys 13 on both ubuntu 10.10 and fedora 12. I followed the tutorial of the elbow. Everything was working until I tried to run CFD-Post (clicking on results)
On both the platform I get this error:
Application Error in CFD-Post
ERROR
CCL validation failed with message:
value 'Coordinate Frame' is not allowed for parameter /DEFAULT INSTANCE TRANSFORMefault Transform/Rotation Axis Type
SEVERE
An attempt to recover from a previous error has failed. The application is likely to be in an unstable state
and in fact the application does not display any contour, vectors and so on.
Anybody knows hot to get it working?
thanks
ffg
Old   February 2, 2011, 11:53
Martin Nesladek
Hello, ffg!
I can't figure out what you mean by:
Can you please post the procedure you have used to get WB working on fedora? Thanks!
Martin
Old   February 3, 2011, 04:56
ffg
surfer
Originally Posted by rasov24 View Post
Hello, ffg!
Martin
The elbow I was talking about is the first tutorial "Tutorial 1. Introduction to Using ANSYS FLUENT in ANSYS WORKBENCH: Fluid Flow and Heat Transfer in a Mixing Elbow"
http://www1.ansys.com/customer/conte...ent/flwbtg.pdf
The procedure to get the workbench (but not CFD-post) working in fedora 12 has been the following:
I missed ld-linux.so.2 , libstdc++.so.6, libXext.so.6, lsb
I installed them with the command "yum install librarytobeinstalled"
install ANSYS 13 disabling SElinux (if you have it) and that's it apart for being cautious to the file /etc/hosts as already written in this forum.
run the program disabling SElinux (if you have it)
Old   February 22, 2011, 08:52
Vadim
Conakry is on a distinguished road
Hi all!
I have the ArchlinuxOS x86_64, Ansys 13 and two questions...
1. Why does DM start so looong time? It`s 10 minutes approximately.
2. Why does ME crach after the looong attempt to start?
My regards!
Conakry is offline   Reply With Quote
Old   February 24, 2011, 09:42
Nikolopoulos Aristeidis
Nikolopoulos is on a distinguished road
Hello!
I cannot install ANSYS13.0 in fedora 14 (64bit)
I used yum -y install INSTALL
but it replies that INSTALL is not a package?
Do you know which file should i yum?????
Nikolopoulos is offline   Reply With Quote
Old   February 24, 2011, 10:20
Vadim
Originally Posted by Nikolopoulos View Post
Hello!
Sure, INSTALL is not a package...it`s shell-script.
You`d run it independently.
Old   February 24, 2011, 10:28
Default THanks for the reply!
  #117
How should i install ANSYS13 in Fedora?
Keep in mind that i'm new to Linux!
Old   February 24, 2011, 10:33
Vadim
That`s simply.
Run any terminal program, enter to Ansys13-media and perform INSTALL-script:
$ ./INSTALL
Old   February 24, 2011, 10:36
Thanks I did it but i got the following
[root@aris Desktop]# ./INSTALL
copying necessary files to /tmp/ans_install_tmp4121/
Executing /tmp/ans_install_tmp4121/instcore
/tmp/ans_install_tmp4121/INSTALL: /tmp/ans_install_tmp4121/instcore: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
Old   February 24, 2011, 10:44
Vadim
Show here your /lib64-folder contents...
LINUX Experts: Help with installing ANSYS workbench faisal_durr ANSYS 1 May 30, 2014 09:07
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 13:59
How can I start the ANSYS 12 workbench in LINUX Ardisia ANSYS 3 September 7, 2010 01:19
ANSYS Workbench on Linux CPUcruncher ANSYS 4 July 11, 2010 10:19
ANSYS Workbench on "Certified" linux distro mechanicaldesign CFX 0 April 16, 2010 02:56
